[AG-TECH] AG3 venue server on both Windows and Linux (FD4)?
Sebastian Tabarce
stabarce at inescporto.pt
Wed Feb 15 11:44:22 CST 2006
Hi Gen-Tao,
If you type "help" at the (ID mode)> prompt you will see a list of
commands that can be used inside the Certificate Manager. I think it's
pretty straightforward to figure out what each does. Using those
commands you can add certificates, set the default certificate, generate
a proxy ....etc. etc.
About the other problem, I suppose AGTK 2.x and 3.0 store the
certificates and configuration files under the same directory, which is
My Documents\%username%\Application Data\AccessGrid and that is why
probably you see the same Venues.
Good luck,
Sebastian
G.T. Chiang wrote:
> Dear All
> since using the Fedora i386. the situation getting better. the
> situation now is needing certificate to run venue server. i applied
> one. however, i was trying to use our own certificate, i could not
> find cert manager as before. if i execute certmgr.py and got this (ID
> mode) > . is cert manager working at linux version this moment?
> about windows verson, I had cert on this machine before, and cert
> manager is wokring on windows, i import the host and running the venue
> server, it seems wroking. however, when i try to use venue management
> tool to add to AG3 venue, i saw previous AG2 venues. how this happend?
> is taht mean I am still running AG2 venue server?, but i even remove
> the AG2 before installing AG3.
> Thank you for any suggestion!!
> Best Regard!
> gen-tao
> On Feb 15 2006, G.T. Chiang wrote:
>> Dear All
>> I try to start the venue server on both Windows and Linux. when I
>> try to start it, it crash immediately both in windwos and linux, i am
>> not sure what exactly happend. i remove previous AG2 and python. and
>> it still not working. clinet seems ok in windows, but not in linux
>> (Fedora 4). th eerror message of linux is like the following:
>> Traceback (most recent call last):
>> File "/usr/bin/VenueClient.py", line 21, in ?
>> from wxPython.wx import wxPySimpleApp
>> File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wxPython/__i
>> y", line 10, in ?
>> import _wx
>> File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wxPython/_wx
>> ine 3, in ?
>> from _core import *
>> File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wxPython/_co
>> line 15, in ?
>> import wx._core
>> File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/__init__.
>> ne 42, in ?
>> from wx._core import *
>> File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-unicode/wx/_core.py"
>> 4, in ?
>> import _core_
>> ImportError:
>> cannot open shared object file: No such file or directory
>> the library is there, and Log is empty.
>> thank you for any suggestion!!
>> Best regard!
>> gen-tao
Sebastian Tabarce
Junior Researcher
INESC Porto
Campus da FEUP - Rua Dr. Roberto Frias, nº 378
4200-465 Porto Portugal
E-mail : stabarce at inescporto.pt
Web : http://www.inescporto.pt
