[AG-TECH] Possible issue with NCSA Server.....
    Wesley Skoczen
    wesley.skoczen at sheridanc.on.ca
    Thu Feb  9 16:00:53 CST 2006
Those are the numbers you will get from Venue-Properties (this is a bug in
AG2 software, video port is not displayed correctly). My Vic is using and
displaying  224.2.218.74/65396, but I can't see your video there -
multicast
problem?
   Wesley
Many Ayromlou wrote:
> Hi,
> I was just playing around with agvcr and went over to ncsa lobby.
> Here is the address details from venueclient/properties:
> Audio: 224.2.233.64/55208 ttl127
> Video: 224.2.218.74/65397 ttl127
> Is it just me or is the video port "off". I was under the impression
> that even number ports were advertised RTP ports and odd ones (rtpport
> +1) were automatically assumed to be RTCP ports. Why is the video for
> lobby running on a odd port. I think this might cause a problem with
> agvcr since when the numbers are entered agvcr assumes 65397 is the
> RTCP port and 65396 is the RTP port......doesn't this screw things up
> a bit?
> Anyways, hope someone has an answer to this......
> TTYL
> Many
