[AG-TECH] AG3 CVS - Files Missing? (solved)
    Ashnil Kumar
    akum5948 at mail.usyd.edu.au
    Wed Feb  8 17:19:22 CST 2006
Tom
Thanks for that. I ran it and it helped me find the problem.
In /System/Library/Frameworks/Python.framework/Versions/Current/bin/:
  'wsdl2py.py' and 'wsdl2dispatch.py' were known as 'wsdl2py' and
'wsdl2dispatch', causing GenerateInterfaces.py to fail because it could
not find the files.
Creating symbolic links for 'wsdl2py.py' and 'wsdl2dispatch.py' in the
directory fixed the issue.
Cheers,
Ash
On 08/02/2006, at 4:41 PM, Thomas D. Uram wrote:
> Ashnil:
> Try running AccessGrid/tools/GenerateInterfaces.py.  That will generate
> Python code in AccessGrid/interfaces from the files in AccessGrid/wsdl.
> This should be getting called automatically by CvsSetup.py.  Is it for
> some
> reason not being called in your case?
> Tom
> On 2/7/06 11:18 PM, Ashnil Kumar wrote:
>> I have recently set up AG3 on Mac OS X 10.3 (using CvsSetup, as I
>> want to look at development in the future rather than just using it
>> now), and when attempting to run from the command line, I have come
>> across a couple of ImportErrors. In both cases, AGTK_LOCATION and
>> PYTHONPATH were correctly set up.
>> AccessGrid/interfaces contains only __init__.py. Are the modules that
>> are not found intentionally not there? The traces are given below.
>> Cheers,
>> Ashnil
>> When running "python VenueClient.py --personalNode"
>> Traceback (most recent call last):
>>   File "VenueClient.py", line 15, in ?
>>     from AccessGrid.hosting import Client
>>   File
>> "/Volumes/Data/mnt/scratch/ag3b/AccessGrid/AccessGrid/hosting/
>> __init__.py", line 134, in ?
>>     SetHostingImpl(__hostingImpl)
>>   File
>> __init__.py", line 70, in SetHostingImpl
>>     s = __import__(nis, globals(), locals(), ["SecureServer",
>>   File
>> "/Volumes/Data/mnt/scratch/ag3b/AccessGrid/AccessGrid/hosting/ZSI/
>> __init__.py", line 24, in ?
>>     from AccessGrid.interfaces.AccessGrid_Types import
>> www_accessgrid_org_v3_0 as AGTypes
>> ImportError: No module named AccessGrid_Types
>> and when running "python VenueServer.py":
>>   File "VenueServer.py", line 25, in ?
>>     from AccessGrid.Toolkit import Service
>>   File
>> "/Volumes/Data/mnt/scratch/ag3b/AccessGrid/AccessGrid/Toolkit.py",
>> line 21, in ?
>>     from AccessGrid.Preferences import Preferences
>>   File
>> Preferences.py", line 12, in ?
>>     from AccessGrid.interfaces.AGNodeService_client import
>> AGNodeServiceIW
>> ImportError: No module named AGNodeService_client
