[AG-TECH] AccessGrid and Polycom
    Ulrich Schwenn
    schwenn at rzg.mpg.de
    Sat Feb  4 01:33:20 CST 2006
Fabrizio,
the ViaVideo is a self sustained H.323 Videosystem and CANNOT be used as
a camera, use any AG compatible webcam from "choosable devices".
Ulli
Fabrizio.Berdondini at prototipo.it wrote:
> Hi Sam,
> Unfortunately I already tried VRVS with no luck, as I got the same
> behaviour: I cannot select my "Polycom ViaVideo II" as camera of my
> personal node, as it doesn't appear on the list of the choosable
> devices: the only one I get is "Microsoft WDM", which crashes when
> using the Polycom camera.
> Any other suggestion?
> Thanx,
> Faber B.
> Sam Liston <stliston at chpc.utah.edu> scritti il 02/02/2006 17.45.13
> > Hi Fabrizio,
> > Your problem, I believe, is that the viavideo2 camera uses h.323 video
> > codec while standard vic uses h.261.  You may want to try VRVS,
> which, I
> > think supports h.323.
> > Sam
> > Samuel T. Liston <stliston at chpc.utah.edu>
> > Systems Administrator - Visualization
> > Univ. of Utah
> >  Center for High Performance Computing
> >   155 S. 1452 E. Room 405
> >   Salt Lake City, Utah 84112
> >   801.232.6932
> > > Hello,
> > > I'm wondering about the possibility to configure and use a "Polycom
> > > ViaVideo II" as VideoProducer Service of a Node, running on a Windows
> > > XP SP1 machine. I connected it to my PC, but when I start the "Manage
> > > my node" utility there's no chance to see it in the list of the
> usable
> > > videocamera devices: I just can see the "Microsoft WDM Image Capture
> > > (Win32)" option, which I usually used when I previously connected a
> > > "Phillip Toucam" instead of the ViaVideo.
> > > I also tried to connect the AG client to the standard server lobby
> > > with the Viavideo switched on, but vic.exe crashes reporting the
> > > following error boxes: "capDriverConnect: dev=0 failed - 0", then
> > > "capGetDriverCaps: failed - 0", finally "capGetVideoFormat: failed -
> > > 0", then ends asking if I am willing to report the error to Microsoft.
> > > The ViaVideo is correctly installed and working, as I can use it with
> > > the "Polycom PVX" conference software, but I have no clue on how to
> > > configure it in order to allow to the "Node Manager" and the "AG
> > > client" to set and use it.
> > > Any suggestion please?
> > > Thank you in advance,
> > > Faber
Dr. Ulrich Schwenn
Head of Multimedia and Videoconferencing Group
Computing Center Garching
Max-Planck-Gesellschaft &
Max-Planck-Institut für Plasmaphysik
Boltzmannstr. 2, D-85748 Garching
GERMANY
Phone: +49 89 3299 1371
H.323: +49 89 3299 6004
Fax: +49 89 3299 1301
e-mail: schwenn at rzg.mpg.de
web: http://www.rzg.mpg.de
