[AG-TECH] AccessGrid and Polycom
Fabrizio.Berdondini at prototipo.it
Fri Feb 3 04:18:14 CST 2006
Hi Sam,
Unfortunately I already tried VRVS with no luck, as I got the same
behaviour: I cannot select my "Polycom ViaVideo II" as camera of my
personal node, as it doesn't appear on the list of the choosable devices:
the only one I get is "Microsoft WDM", which crashes when using the
Polycom camera.
Any other suggestion?
Thanx,
Faber B.
Sam Liston <stliston at chpc.utah.edu> scritti il 02/02/2006 17.45.13
> Hi Fabrizio,
> Your problem, I believe, is that the viavideo2 camera uses h.323 video
> codec while standard vic uses h.261. You may want to try VRVS, which, I
> think supports h.323.
> Sam
> Samuel T. Liston <stliston at chpc.utah.edu>
> Systems Administrator - Visualization
> Univ. of Utah
> Center for High Performance Computing
> 155 S. 1452 E. Room 405
> Salt Lake City, Utah 84112
> 801.232.6932
> Fabrizio.Berdondini at prototipo.it wrote:
> > Hello,
> > I'm wondering about the possibility to configure and use a "Polycom
> > ViaVideo II" as VideoProducer Service of a Node, running on a Windows
> > XP SP1 machine. I connected it to my PC, but when I start the "Manage
> > my node" utility there's no chance to see it in the list of the usable
> > videocamera devices: I just can see the "Microsoft WDM Image Capture
> > (Win32)" option, which I usually used when I previously connected a
> > "Phillip Toucam" instead of the ViaVideo.
> > I also tried to connect the AG client to the standard server lobby
> > with the Viavideo switched on, but vic.exe crashes reporting the
> > following error boxes: "capDriverConnect: dev=0 failed - 0", then
> > "capGetDriverCaps: failed - 0", finally "capGetVideoFormat: failed -
> > 0", then ends asking if I am willing to report the error to Microsoft.
> > The ViaVideo is correctly installed and working, as I can use it with
> > the "Polycom PVX" conference software, but I have no clue on how to
> > configure it in order to allow to the "Node Manager" and the "AG
> > client" to set and use it.
> > Any suggestion please?
> > Thank you in advance,
> > Faber
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20060203/f92366a2/attachment.htm>
