[AG-TECH] Bridge Server v2.4 does nothing
    Michael Groufsky
    michael.groufsky at canterbury.ac.nz
    Tue Dec 19 00:56:59 CST 2006
Ah, no.  I pulled the archived RPMs from
http://www.vislab.uq.edu.au/research/accessgrid/software/fedora/ag2/,
since I had previously had similar troubles with the compat package.
Not sure if it was the same problem, though, so I will try it again.
Michael Groufsky
Douglas Kosovic wrote:
> Hi Michael,
>> I am trying to set up an AG2.4 bridge server, to bridge a single
>> venue. I am running Fedora core 6, and have created a
>> BridgeServer.cfg file based on the one provided at the start of the
>> BridgeServer.py source file. Haven't done any other configuration,
>> except launching VenueClient to bring in certificate.
>> When I launch BridgeServer.py, the process starts, but nothing
>> happens. No output is produced (from what I understand, should see
>> some info from QuickBridge startup), and the VenueClient 'Use
>> unicast' option is still unavailable when someone tries to connect to
>> the venue.
> Which AGTk 2.4 are you running? It doesn't appear to be the
> compat-AccessGrid 2.4 FC6 RPMs from:
>   http://www.vislab.uq.edu.au/research/accessgrid/software/fedora/ag3/
> which has /usr/bin/BridgeServer24 instead of /usr/bin/BridgeServer.py
> Doug
