[AG-TECH] Bridge Server v2.4 does nothing
Michael Groufsky
michael.groufsky at canterbury.ac.nz
Mon Dec 18 23:45:09 CST 2006
Hello,
I am trying to set up an AG2.4 bridge server, to bridge a single venue.
I am running Fedora core 6, and have created a BridgeServer.cfg file
based on the one provided at the start of the BridgeServer.py source
file. Haven't done any other configuration, except launching
VenueClient to bring in certificate.
When I launch BridgeServer.py, the process starts, but nothing happens.
No output is produced (from what I understand, should see some info from
QuickBridge startup), and the VenueClient 'Use unicast' option is still
unavailable when someone tries to connect to the venue.
Looking in the BridgeServer.log file, I see the following sequence of
messages repeated roughly every 10 seconds:
12/19/06 17:28:22 145009552 Toolkit BridgeServer.py:644 INFO Trying
to reach venue
12/19/06 17:28:22 145009552 Toolkit BridgeServer.py:649 INFO -
venue reachable;
url=https://202.36.178.214:8000/Venues/0000010f85947f11008400b500f700aaf29
12/19/06 17:28:22 55802768 EventClient EventClient.py:177 DEBUG Read
Callback called arg=None handle=_b88a070a_p_globus_io_handle_t
result=(40, 'an end-of-file was reached') n=0
12/19/06 17:28:22 55802768 EventClient EventClient.py:180 DEBUG
readCallback gets failure in result: 40 an end-of-file was reached
12/19/06 17:28:22 145009552 EventClient EventClient.py:158 DEBUG
Have callback handle _d8d5fb09_p_callbackStruct
12/19/06 17:28:22 145009552 Toolkit BridgeServer.py:656 INFO event
client connected;
12/19/06 17:28:22 145009552 Toolkit BridgeServer.py:657 INFO -
re-creating bridges;
12/19/06 17:28:23 -1225884784 Toolkit BridgeServer.py:644 INFO
Trying to reach venue
12/19/06 17:28:23 -1225884784 Toolkit BridgeServer.py:649 INFO -
venue reachable;
url=https://ag2venue.karen.canterbury.ac.nz:8000/Venues/default
12/19/06 17:28:23 45312912 EventClient EventClient.py:177 DEBUG Read
Callback called arg=None handle=_883e090a_p_globus_io_handle_t
result=(52, 'an end-of-file was reached') n=0
12/19/06 17:28:23 45312912 EventClient EventClient.py:180 DEBUG
readCallback gets failure in result: 52 an end-of-file was reached
12/19/06 17:28:24 -1225884784 EventClient EventClient.py:158 DEBUG
Have callback handle _18d7030a_p_callbackStruct
12/19/06 17:28:24 -1225884784 Toolkit BridgeServer.py:656 INFO
event client connected;
12/19/06 17:28:24 -1225884784 Toolkit BridgeServer.py:657 INFO -
Perhaps someone could tell me if this is expected, or if it is showing
there is some sort of problem.
Michael Groufsky
Assistant Hardware Engineer
HIT Lab NZ
