[AG-TECH] matchmaker question
Todd Zimmerman
toddz at sfu.ca
Wed Aug 16 14:07:04 CDT 2006
Should also note that it isn't that you need a 'Matchmaker' specifically - you need to have some
sort of balanced / unbalanced converter system in place. Talk with your local A/V supplier company
- they may have a cheaper solution.
As an aside, for the line out connection, I've used the Extron ASA101 (now I think it's been
superseded by the ASA141) which will take stereo unbalanced (line out of the computer) and convert
it to mono balanced (ClearOne Input) directly. Specs here:
http://www.extron.com/product/product.asp?id=asa141&version=print
Cheers,
Todd
Ivan R. Judson wrote:
> I would further add a clarification:
> Yes, it is required for exactly the reasons Michael points out.
> --Ivan
>> -----Original Message-----
>> From: owner-ag-tech at mcs.anl.gov
>> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Miller
>> Sent: Tuesday, August 15, 2006 10:13 AM
>> To: AG-TECH mailing list
>> Subject: Re: [AG-TECH] matchmaker question
>> Lisa,
>> The matchmaker converts the impedance from the XAP or other
>> echo cancellation device to the sound card and vice-versa.
>> The result is that you have more head room to make
>> adjustments in level. Without it, you wind up having to set
>> the volume on the audio machine very very low, and you can't
>> bring it up without causing a lot of distortion and blowing
>> out ears across the AG.
>> hope this helps
>> Michael Miller
>> NCSA
>> Lisa Metz wrote:
>>> Hello,
>>> I'm in the process of FINALLY setting up a node and am
>> wondering what
>>> the purpose of the Matchmaker is and whether it is a requirement.
>>> Thank you all for your help so far and continued assistance in the
>>> future as I'm sure I'll have more questions.
>>> Lisa
>> Thanx,
>> Michael Miller
>> System Engineer
>> Video Technology Services
>> Persistent Infrastructure Directorate
>> National Center for Supercomputing Applications University of
>> Illinois - UC
>> 217-649-0747
>> "If you're clear in your vision and trust the people in your
>> team with clear objectives, they will invariably do their
>> best to achieve everything desired, and usually deliver
>> everything you could have hoped for and even more." -Paul Debevec
