[AG-TECH] matchmaker question
Ivan R. Judson
judson at mcs.anl.gov
Tue Aug 15 11:15:00 CDT 2006
I would further add a clarification:
Yes, it is required for exactly the reasons Michael points out.
--Ivan
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov
> [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Michael Miller
> Sent: Tuesday, August 15, 2006 10:13 AM
> To: AG-TECH mailing list
> Subject: Re: [AG-TECH] matchmaker question
> Lisa,
> The matchmaker converts the impedance from the XAP or other
> echo cancellation device to the sound card and vice-versa.
> The result is that you have more head room to make
> adjustments in level. Without it, you wind up having to set
> the volume on the audio machine very very low, and you can't
> bring it up without causing a lot of distortion and blowing
> out ears across the AG.
> hope this helps
> Michael Miller
> NCSA
> Lisa Metz wrote:
> > Hello,
> > I'm in the process of FINALLY setting up a node and am
> wondering what
> > the purpose of the Matchmaker is and whether it is a requirement.
> > Thank you all for your help so far and continued assistance in the
> > future as I'm sure I'll have more questions.
> > Lisa
> Thanx,
> Michael Miller
> System Engineer
> Video Technology Services
> Persistent Infrastructure Directorate
> National Center for Supercomputing Applications University of
> Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your
> team with clear objectives, they will invariably do their
> best to achieve everything desired, and usually deliver
> everything you could have hoped for and even more." -Paul Debevec
