[AG-TECH] AG3 and AG2.4 server on same machine
Derek Piper
dcpiper at indiana.edu
Mon Aug 14 09:37:21 CDT 2006
Hi Michael,
There was a thread last week about it. You could have a look here for
more info:
http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2006/08/msg00027.html
I have the lines 'eventPort = 9002' and 'dataPort = 9006' in my AG3
Venue server config. The textPort one should be 'textPort = 5223' for
the Jabber stuff.
Feel free to email me off-list if you want me to send you my config files.
Derek
Michael Braitmaier wrote:
> Hi Derek!
> You mentioned changing the config files. Could you point me out to the
> way on how to modify the config file for changing the ports of the
> VenueServer?
> Thanks
> Michael
> Derek Piper schrieb:
>> Having just run into the same problem myself, I agree that would
>> indeed be a smart idea. It would save editing of the config files just
>> to move the port range. Many people aren't going to want to have to
>> fiddle in order to get things to work.
>> I'm not even sure why the default was kept the same between AG2
>> and AG3 when it's obvious they'll have to be run side-by-side for
>> quite a while as people gradually change over.
>> Derek
>>> I am in the progress of setting up AG3 and AG2.4 servers on the same
>>> machine Fedora Core 5.
>>> When I now run the AG2.4 server with option -P 9000 to move it to the
>>> appropriate port to avoid port
>>> overlapping of the two servers, it gives me the following output:
>>> Server: https://agserver.hlrs.de:9000/VenueServer
>>> Event Port: 8002 Text Port: 8004 Data Port: 8006
>>> Default Venue Url: https://agserver.hlrs.de:9000/Venues/default
>>> This gives me the conclusion that the server listens on 9000 but
>>> events, text and data arrives at 8002,8004 and 8006 which would then
>>> overlap with a second server running on the machine?
>>> In fact when running the AG3 server in parallel it doesnt start,
>>> leaving with the follwoing error message:
>>> Couldn't listen on any:8002: (98, 'Address already in use').
>>> Error occurred running server: Couldn't listen on any:8002: (98,
>>> 'Address
>>> already in use').
>>> Traceback (most recent call last):
>>> File "/usr/lib/python2.4/logging/handlers.py", line 71, in emit
>>> if self.shouldRollover(record):
>>> File "/usr/lib/python2.4/logging/handlers.py", line 143, in
>>> shouldRollover
>>> self.stream.seek(0, 2) #due to non-posix-compliant Windows feature
>>> ValueError: I/O operation on closed file
>>> Exception in thread ftps server:
>>> File "/usr/lib/python2.4/threading.py", line 442, in __bootstrap
>>> self.run()
>>> File "/usr/lib/python2.4/threading.py", line 422, in run
>>> self.__target(*self.__args, **self.__kwargs)
>>> File "/usr/lib/python2.4/site-packages/AccessGrid/FTPSServer.py",
>>> line 66,
>>> in run
>>> log_obj=log)
>>> File
>>> "/usr/lib/python2.4/site-packages/AccessGrid/FTPS/ftps_server.py", line
>>> 317, in __init__
>>> self.bind((self.ip, self.port))
>>> File "/usr/lib/python2.4/asyncore.py", line 304, in bind
>>> return self.socket.bind(addr)
>>> File "<string>", line 1, in bind
>>> error: (98, 'Address already in use')
>>> Wouldn't it make sense to alter the VenueServer to have the whole
>>> port used
>>> range moved based on the base port given with the switch -p ?
>>> for example
>>> VenueServer24 -p 8000
>>> Event: 8002 Text: 8004 Data: 8006
>>> VenueServer - p 9000
>>> Event: 9002 Text: 9004 Data: 9006
>>> I think this would at least make sense in AG3 for the future which
>>> also allows to run it in parallel with Ag2.4, when launching AG3 on
>>> ports different than 8000.
>>> Michael
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
