[AG-TECH] Error Launching AG2.4
Chris Kendrick
kendrick at vpac.org
Thu Aug 10 02:42:55 CDT 2006
Thanks Doug and Chris
Yes the system had been upgraded from FC4 to FC5 rather than a fresh
install.
It appears that some of the rpm's were FC4 versions even though the
system had been updated to FC5 =-/
The very first thing I did when AG2.4 failed to launch was "yum remove
compat-AccessGrid" then "yum install compat-AccessGrid" why did
compat-AccessGrid not complain about failed dependencies? when the
following is what fixed the situation.
rpm -e wxPython-common-gtk2-ansi wxPython2.6-gtk2-ansi
wxPython2.6-devel-gtk2-ansi compat-AccessGrid
then
yum install wxPython
Did the trick
Chris Kendrick
VPAC
On Thu, 2006-08-10 at 12:26 +1000, Christoph Willing wrote:
> On 10/08/2006, at 11:50 AM, Chris Kendrick wrote:
> > Hi
> > For some reason I get the attached error when trying to launch AG2.4
> > "VenueClient24 --personalNode" on a FC5 install.
> > It appears to be because the object file libgstplay-0.8.so.0 is not
> > installed, but it is also not installed (or anything similar) on
> > another
> > FC5 Box with AG2.4 installed on it and that works fine.
> > Both boxes have gstreamer-0.10.4-1 so I'm not quite sure what is
> > particularly wrong.
> Looks like a dependecy in wxPython. Are they the same versions on
> both your machines? The other FC5 box may have a different version or
> build of wxPython which doesn't need libgstplay.
> chris
> Christoph Willing +61 7 3365 8350
> QCiF/QPSF Access Grid Manager
> University of Queensland
