[AG-TECH] Error Launching AG2.4
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Aug 9 08:08:39 CDT 2006
Hi Chris,
> For some reason I get the attached error when trying to launch AG2.4
> "VenueClient24 --personalNode" on a FC5 install.
> It appears to be because the object file libgstplay-0.8.so.0 is not
> installed, but it is also not installed (or anything similar) on another
> FC5 Box with AG2.4 installed on it and that works fine.
> Both boxes have gstreamer-0.10.4-1 so I'm not quite sure what is
> particularly wrong.
I'm guessing your FC5 install is contaminated with FC4 RPMs as FC4 uses
gstreamer 0.8.
Did you do a FC5 clean install or an upgrade from a FC4 install? Could try a
'yum update wxPython', if that it still doesn't work, try 'rpm -e --nodeps'
all the wx* RPMs and then reinstall them with 'yum install wxPython'.
Cheers,
Doug
