[AG-TECH] AG2 and AG3 venue servers on one machine
Thomas D. Uram
turam at mcs.anl.gov
Mon Aug 7 15:04:38 CDT 2006
It's a known shortcoming of the venue tree view that it recurses; we
should terminate
the tree.
If you could file the bug re: authorizationPolicy, that'd be great.
Tom
On 8/7/06 2:45 PM, Derek Piper wrote:
> Okay, thanks.
> Sure enough doing:
> cat ../VenueServer/VenueServer.cfg | grep -v 'authorizationPolicy'
> >VenueServer.cfg
> cat ../VenueServer/VenueServer.dat | grep -v 'authorizationPolicy'
> >VenueServer.dat
> And then editing the AG3 VenueServer.cfg for the correct ports
> yields a working AG3 and AG2 venue server with the same rooms on the
> same machine. The AG2 exits/links makes the tree layout on AG3 a bit
> strange since it then recurses infinitely. What's the 'approved' way
> to lay out rooms on AG3? Exits back to the root?
> I'll file it as a bug if you like, Tom?
> Thanks,
> Derek
> Thomas D. Uram wrote:
>> Using an AG2 VenueServer.dat will work fine, with one revision: You
>> should remove the 'authorizationPolicy' lines
>> from VenueServer.dat. AG3 runs into trouble with those existing
>> lines. This should be filed as a bug.
>> Tom
>> On 8/7/06 2:17 PM, Derek Piper wrote:
>>> Thanks, Tom, for the clarification. I've tried again this time
>>> running AG2 as 900x and AG3 as 800x. I have both of them running,
>>> AG2 clients can connect (I realized my problem before was that the
>>> AG3 Venue Server just wouldn't die until it was sent a -9). The AG3
>>> venue server config has 5223 in its 'textPort' field now.
>>> AG3 clients however still cannot connect, even with its default
>>> settings (which seems that my problems are somewhere else). I get a
>>> 'HTTP Digest Authorization Failed' error from the AG3 venue client
>>> when trying to connect to it. Both machines are using AG 3.0.1 (the
>>> Fedora Core 5 venue server machine, and the Windows client machine).
>>> In starting the AG3 venue server, I copied the previous venue
>>> server (2.4) data to a new directory and the AG3 venue server is
>>> started from there. Is that a good idea? Will that work to recreate
>>> the same setup that I have with the 2.x venue server?
>>> Derek
>>>> A little clarification:
>>>> - the --port argument only specifies the main port, not the related
>>>> (event,data,text) ports (unfrotunately)
>>>> - the event,data,text ports are specified only in the cfg file
>>>> - text does _not_ use 9004 or similar in AG3; instead, textHost and
>>>> textPort point at a
>>>> Jabber server (using jabber.mcs.anl.gov:5223 by default)
>>>> Derek:
>>>> I'd suggest you modify the AG3 venueserver.cfg to specify:
>>>> textHost = jabber.mcs.anl.gov
>>>> textPort = 5223
>>>> and then try to start it. If you want to use your own jabber
>>>> server instead,
>>>> you would modify textHost accordingly.
>>>> Tom
>>>> On 8/7/06 12:58 PM, Derek Piper wrote:
>>>>> Yes, I originally had my 2.x server at port 8000, apparently
>>>>> the default. So.. now we have two incompatible venue servers that
>>>>> all want to be the same default? That was a smart idea :>
>>>>> Since I already have 2.x installations around that use the one
>>>>> on port 8000 as a default/home venue, I thought I'd just add AG3
>>>>> on as port 9000. Now, I guess it's possible to try it the other
>>>>> way and just run to all my installations and change them. In
>>>>> trying to run the AG2 venue server on port 900x, it doesn't start
>>>>> its text chat thing on port 9004 either. Nothing's running on that
>>>>> port. And, just like it was with AG3, a venue client can't connect
>>>>> to it.
>>>>> I have the ports specified in VenueServer.cfg. All, but the
>>>>> 'textPort' one seem to work. The text chat thing isn't even trying
>>>>> to bind to port 8004 either, so I'm not sure what's up with that.
>>>>> Do I have to redo my venue server from scratch if I change the port?
>>>>> I was specifying the text, event and date ports for AG3, yes.
>>>>> I had them set to the 900x equivalants and a venue client couldn't
>>>>> connect to it.
>>>>> Derek
>>>>> Michael Miller wrote:
>>>>>> Derek,
>>>>>> I run AG2 on port 900x and AG3 on 800x. I specify the text,
>>>>>> event and data ports for AG2 in VenueServer.cfg and everything
>>>>>> seems to work fine. Are you specifying the text,event and data
>>>>>> ports for AG3?
>>>>>> myk
>>>>>> Derek Piper wrote:
>>>>>>> Hi,
>>>>>>> I've installed AG2 and AG3 venue servers on one machine,
>>>>>>> with the idea of having them co-exist but running on different
>>>>>>> ports. I noticed that even if I specify a port of 9000 to the
>>>>>>> AG3 venue server, it still wants to listen on 8002 etc. That
>>>>>>> seems a bit unhelpful. I've been able to get both of them
>>>>>>> running by having a VenueServer.cfg file but, but the AG3
>>>>>>> VenueServer isn't listening for its text chat port of 9004. Does
>>>>>>> the AG3 VenueServer have to listen on port 8000? I don't really
>>>>>>> want to have yet another box just to run the venue server, but
>>>>>>> is that the only recommended way of setting them up?
>>>>>>> Another question related to this is about keeping the two
>>>>>>> venue servers synchronized. For the time being, it's going to be
>>>>>>> likely to have to run both side by side. It would be nice if the
>>>>>>> configuration from one could be mirrored from another and
>>>>>>> synchronized either by a manual or automatic operation without
>>>>>>> having to perform the same edits in each.
>>>>>>> Hints are appreciated. Thanks,
>>>>>>> Derek
