[AG-TECH] AG2 and AG3 venue servers on one machine
Derek Piper
dcpiper at indiana.edu
Mon Aug 7 14:45:51 CDT 2006
Okay, thanks.
Sure enough doing:
cat ../VenueServer/VenueServer.cfg | grep -v 'authorizationPolicy'
>VenueServer.cfg
cat ../VenueServer/VenueServer.dat | grep -v 'authorizationPolicy'
>VenueServer.dat
And then editing the AG3 VenueServer.cfg for the correct ports yields a
working AG3 and AG2 venue server with the same rooms on the same
machine. The AG2 exits/links makes the tree layout on AG3 a bit strange
since it then recurses infinitely. What's the 'approved' way to lay out
rooms on AG3? Exits back to the root?
I'll file it as a bug if you like, Tom?
Derek
Thomas D. Uram wrote:
> Using an AG2 VenueServer.dat will work fine, with one revision: You
> should remove the 'authorizationPolicy' lines
> from VenueServer.dat. AG3 runs into trouble with those existing lines.
> This should be filed as a bug.
> Tom
> On 8/7/06 2:17 PM, Derek Piper wrote:
>> Thanks, Tom, for the clarification. I've tried again this time
>> running AG2 as 900x and AG3 as 800x. I have both of them running, AG2
>> clients can connect (I realized my problem before was that the AG3
>> Venue Server just wouldn't die until it was sent a -9). The AG3 venue
>> server config has 5223 in its 'textPort' field now.
>> AG3 clients however still cannot connect, even with its default
>> settings (which seems that my problems are somewhere else). I get a
>> 'HTTP Digest Authorization Failed' error from the AG3 venue client
>> when trying to connect to it. Both machines are using AG 3.0.1 (the
>> Fedora Core 5 venue server machine, and the Windows client machine).
>> In starting the AG3 venue server, I copied the previous venue
>> server (2.4) data to a new directory and the AG3 venue server is
>> started from there. Is that a good idea? Will that work to recreate
>> the same setup that I have with the 2.x venue server?
>> Derek
>>> A little clarification:
>>> - the --port argument only specifies the main port, not the related
>>> (event,data,text) ports (unfrotunately)
>>> - the event,data,text ports are specified only in the cfg file
>>> - text does _not_ use 9004 or similar in AG3; instead, textHost and
>>> textPort point at a
>>> Jabber server (using jabber.mcs.anl.gov:5223 by default)
>>> Derek:
>>> I'd suggest you modify the AG3 venueserver.cfg to specify:
>>> textHost = jabber.mcs.anl.gov
>>> textPort = 5223
>>> and then try to start it. If you want to use your own jabber server
>>> instead,
>>> you would modify textHost accordingly.
>>> Tom
>>> On 8/7/06 12:58 PM, Derek Piper wrote:
>>>> Yes, I originally had my 2.x server at port 8000, apparently the
>>>> default. So.. now we have two incompatible venue servers that all
>>>> want to be the same default? That was a smart idea :>
>>>> Since I already have 2.x installations around that use the one
>>>> on port 8000 as a default/home venue, I thought I'd just add AG3 on
>>>> as port 9000. Now, I guess it's possible to try it the other way and
>>>> just run to all my installations and change them. In trying to run
>>>> the AG2 venue server on port 900x, it doesn't start its text chat
>>>> thing on port 9004 either. Nothing's running on that port. And, just
>>>> like it was with AG3, a venue client can't connect to it.
>>>> I have the ports specified in VenueServer.cfg. All, but the
>>>> 'textPort' one seem to work. The text chat thing isn't even trying
>>>> to bind to port 8004 either, so I'm not sure what's up with that. Do
>>>> I have to redo my venue server from scratch if I change the port?
>>>> I was specifying the text, event and date ports for AG3, yes. I
>>>> had them set to the 900x equivalants and a venue client couldn't
>>>> connect to it.
>>>> Derek
>>>> Michael Miller wrote:
>>>>> Derek,
>>>>> I run AG2 on port 900x and AG3 on 800x. I specify the text, event
>>>>> and data ports for AG2 in VenueServer.cfg and everything seems to
>>>>> work fine. Are you specifying the text,event and data ports for AG3?
>>>>> myk
>>>>> Derek Piper wrote:
>>>>>> Hi,
>>>>>> I've installed AG2 and AG3 venue servers on one machine, with
>>>>>> the idea of having them co-exist but running on different ports. I
>>>>>> noticed that even if I specify a port of 9000 to the AG3 venue
>>>>>> server, it still wants to listen on 8002 etc. That seems a bit
>>>>>> unhelpful. I've been able to get both of them running by having a
>>>>>> VenueServer.cfg file but, but the AG3 VenueServer isn't listening
>>>>>> for its text chat port of 9004. Does the AG3 VenueServer have to
>>>>>> listen on port 8000? I don't really want to have yet another box
>>>>>> just to run the venue server, but is that the only recommended way
>>>>>> of setting them up?
>>>>>> Another question related to this is about keeping the two
>>>>>> venue servers synchronized. For the time being, it's going to be
>>>>>> likely to have to run both side by side. It would be nice if the
>>>>>> configuration from one could be mirrored from another and
>>>>>> synchronized either by a manual or automatic operation without
>>>>>> having to perform the same edits in each.
>>>>>> Hints are appreciated. Thanks,
>>>>>> Derek
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
