[AG-TECH] AG2 and AG3 venue servers on one machine
Derek Piper
dcpiper at indiana.edu
Mon Aug 7 14:17:40 CDT 2006
Thanks, Tom, for the clarification. I've tried again this time running
AG2 as 900x and AG3 as 800x. I have both of them running, AG2 clients
can connect (I realized my problem before was that the AG3 Venue Server
just wouldn't die until it was sent a -9). The AG3 venue server config
has 5223 in its 'textPort' field now.
AG3 clients however still cannot connect, even with its default
settings (which seems that my problems are somewhere else). I get a
'HTTP Digest Authorization Failed' error from the AG3 venue client when
trying to connect to it. Both machines are using AG 3.0.1 (the Fedora
Core 5 venue server machine, and the Windows client machine).
In starting the AG3 venue server, I copied the previous venue server
(2.4) data to a new directory and the AG3 venue server is started from
there. Is that a good idea? Will that work to recreate the same setup
that I have with the 2.x venue server?
Derek
Thomas D. Uram wrote:
> A little clarification:
> - the --port argument only specifies the main port, not the related
> (event,data,text) ports (unfrotunately)
> - the event,data,text ports are specified only in the cfg file
> - text does _not_ use 9004 or similar in AG3; instead, textHost and
> textPort point at a
> Jabber server (using jabber.mcs.anl.gov:5223 by default)
> Derek:
> I'd suggest you modify the AG3 venueserver.cfg to specify:
> textHost = jabber.mcs.anl.gov
> textPort = 5223
> and then try to start it. If you want to use your own jabber server
> instead,
> you would modify textHost accordingly.
> Tom
> On 8/7/06 12:58 PM, Derek Piper wrote:
>> Yes, I originally had my 2.x server at port 8000, apparently the
>> default. So.. now we have two incompatible venue servers that all want
>> to be the same default? That was a smart idea :>
>> Since I already have 2.x installations around that use the one on
>> port 8000 as a default/home venue, I thought I'd just add AG3 on as
>> port 9000. Now, I guess it's possible to try it the other way and just
>> run to all my installations and change them. In trying to run the AG2
>> venue server on port 900x, it doesn't start its text chat thing on
>> port 9004 either. Nothing's running on that port. And, just like it
>> was with AG3, a venue client can't connect to it.
>> I have the ports specified in VenueServer.cfg. All, but the
>> 'textPort' one seem to work. The text chat thing isn't even trying to
>> bind to port 8004 either, so I'm not sure what's up with that. Do I
>> have to redo my venue server from scratch if I change the port?
>> I was specifying the text, event and date ports for AG3, yes. I
>> had them set to the 900x equivalants and a venue client couldn't
>> connect to it.
>> Derek
>> Michael Miller wrote:
>>> Derek,
>>> I run AG2 on port 900x and AG3 on 800x. I specify the text, event
>>> and data ports for AG2 in VenueServer.cfg and everything seems to
>>> work fine. Are you specifying the text,event and data ports for AG3?
>>> myk
>>> Derek Piper wrote:
>>>> Hi,
>>>> I've installed AG2 and AG3 venue servers on one machine, with
>>>> the idea of having them co-exist but running on different ports. I
>>>> noticed that even if I specify a port of 9000 to the AG3 venue
>>>> server, it still wants to listen on 8002 etc. That seems a bit
>>>> unhelpful. I've been able to get both of them running by having a
>>>> VenueServer.cfg file but, but the AG3 VenueServer isn't listening
>>>> for its text chat port of 9004. Does the AG3 VenueServer have to
>>>> listen on port 8000? I don't really want to have yet another box
>>>> just to run the venue server, but is that the only recommended way
>>>> of setting them up?
>>>> Another question related to this is about keeping the two venue
>>>> servers synchronized. For the time being, it's going to be likely to
>>>> have to run both side by side. It would be nice if the configuration
>>>> from one could be mirrored from another and synchronized either by a
>>>> manual or automatic operation without having to perform the same
>>>> edits in each.
>>>> Hints are appreciated. Thanks,
>>>> Derek
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
