[AG-TECH] wxPython 2.6 with AG2.4
Douglas Kosovic
douglask at itee.uq.edu.au
Mon Apr 24 06:29:40 CDT 2006
Hi Fred,
On Fri, 2006-04-21 at 10:08 -0500, Fred Dech wrote:
> Since yesterday, I've been wondering what the incompatibility is between
> wxPython 2.5 and AG3.0b2. I've had AG2.4 and AG3.0b2 installed on the same
> WinXP node for some time with no problems.
wxPython 2.5 is from the unstable wxPython release series, see:
http://wiki.wxpython.org/index.cgi/ReleaseSeries
so effectively the latest wxPython 2.5.x is a pre-release of the stable
wxPython 2.6.0.
> As was posted a while back, wxPython 2.6 isn't completely
> compatible with AG2.4. I'd not run into this first hand until we were
> doing some shared-app tests yesterday and, as was posted, the Win Shared
> Web Browser (IE) did not work for AG2.4 with wxPython2.6. The browser works
> fine with AG3.0b2/wxPython2.6. It also works fine for both AG2.4 and AG3.0b2
> with wxPython2.5.
The change happened sometime in the wxPython 2.5.x series, you are most
likely using a earlier version of wxPython 2.5 which supports both
wx.iewin and wx.lib.iewin modules.
See the "SharedBrowser broken with wxPython 2.6" bugzilla report:
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1450
Doug
