[AG-TECH] Bridge server
    Todd Zimmerman
    toddz at sfu.ca
    Wed Apr 19 11:44:07 CDT 2006
Agreed.  We've been bridging our entire venueserver for years.  We only run into issues when we
overlap venueserver and venue configs.
Given the importance/need for many of us to statically assign bridge ports, will this functionality
be available in AG3?
Todd
Thomas D. Uram wrote:
> Bridging an entire venue server is supported just fine in my experience.
> There may be problems if the config specifies an overlapping set by,
> say, specifying a venue server and individual venues on that server;
> these should be regarded as mutually exclusive options and, I think,
> in most practical situations, they are.
> Tom
> On 4/19/06 9:33 AM, Michael Braitmaier wrote:
>> Jeremy Mann schrieb:
>>> So basically I have to manually bridge each room. In my config file I
>>> tried to set the entire VenueServer to only use a range of ports, then I
>>> entered ports for the rooms I wanted to configure statically. But I
>>> still
>>> came across that "Address already in use" problem.
>>> For example, I have the VenueServer set to 5000-5200 and 4 Venues to
>>> 5202
>>> on up.
>> I don't specifiy the ports for the venue server overall. Beside I
>> think bridging a whole venue server is not that well supported.
>> You have to specify the ports for each venue seperately. If you refer
>> to the ports of the VenueServer itself, these are configured through
>> the VenueServer
>> configuration. As fas I know through the VenueServer.cfg file, but I
>> didn't succeed in configuring it yet.
>> Michael
>>> Michael Braitmaier said:
>>>> I am doing basically the same. I restrict the range of the ports for
>>>> unicast for a specific venue.
>>>> Config-File example:
>>>> [https://rusagvideo.rus.uni-stuttgart.de:8000/Venues/000001026deebc1400c0006c00230006555]
>>>> type=Venue
>>>> portMin=50096
>>>> portMax=50099
>>>> One of the problems rising with this configuration method is that
>>>> normally AG selects ports on a random
>>>> pattern put of the range you specified in the config file.
>>>> Ports for rat and vic are allocated sequentially.
>>>> So first rat gets assigned 50096 for example.
>>>> When the port for vic should  be determined, it can happen due to the
>>>> nature of the random allocation
>>>> that for vic also 50096 is initially selected. This of course leads
>>>> to a
>>>> "Address already in use" error.
>>>> I avoided the problem by patching the AccessGrid files responsible for
>>>> port allocation to keep a list
>>>> of ports which are in use and have the allocation algorithm first check
>>>> if a port the algorithm wants to allocate
>>>> isn't in use yet.
>>>> Otherwise you have to restart the bridge server until you don't get the
>>>> "address already in use" error to be sure you really have
>>>> video and audio correctly bridged.
>>>> Michael
>>>>> Thomas D. Uram said:
>>>>>> Which version of AG software are you using for BridgeServer and
>>>>>> VenueServer?
>>>>>> Can you post your full bridge cfg file?
>>>>> AG 2.4. Attached is the config file. Worth noted is that I no
>>>>> longer get
>>>>> those python errors, however, now when I start it, several of the
>>>>> venues
>>>>> aren't bridged because the bridgeserver says the address is already in
>>>>> use
>>>> Dipl.-Inf. Michael Braitmaier
>>>> HLRS - Visualization / Video Conferencing
>>>> University of Stuttgart
>>>> Germany
>>>> Phone: ++49 711 685 5996
>>>> Fax  : ++49 711 682 357
>>>> Website: http://www.hlrs.de/people/braitmaier/
