[AG-TECH] Bridge server
    Thomas D. Uram
    turam at mcs.anl.gov
    Wed Apr 19 10:29:45 CDT 2006
Bridging an entire venue server is supported just fine in my experience.
There may be problems if the config specifies an overlapping set by,
say, specifying a venue server and individual venues on that server;
these should be regarded as mutually exclusive options and, I think,
in most practical situations, they are.
Tom
On 4/19/06 9:33 AM, Michael Braitmaier wrote:
> Jeremy Mann schrieb:
>> So basically I have to manually bridge each room. In my config file I
>> tried to set the entire VenueServer to only use a range of ports, then I
>> entered ports for the rooms I wanted to configure statically. But I still
>> came across that "Address already in use" problem.
>> For example, I have the VenueServer set to 5000-5200 and 4 Venues to 5202
>> on up.
> I don't specifiy the ports for the venue server overall. Beside I think
> bridging a whole venue server is not that well supported.
> You have to specify the ports for each venue seperately. If you refer to
> the ports of the VenueServer itself, these are configured through the
> VenueServer
> configuration. As fas I know through the VenueServer.cfg file, but I
> didn't succeed in configuring it yet.
> Michael
>> Michael Braitmaier said:
>>> I am doing basically the same. I restrict the range of the ports for
>>> unicast for a specific venue.
>>> Config-File example:
>>> [https://rusagvideo.rus.uni-stuttgart.de:8000/Venues/000001026deebc1400c0006c00230006555]
>>> type=Venue
>>> portMin=50096
>>> portMax=50099
>>> One of the problems rising with this configuration method is that
>>> normally AG selects ports on a random
>>> pattern put of the range you specified in the config file.
>>> Ports for rat and vic are allocated sequentially.
>>> So first rat gets assigned 50096 for example.
>>> When the port for vic should  be determined, it can happen due to the
>>> nature of the random allocation
>>> that for vic also 50096 is initially selected. This of course leads to a
>>> "Address already in use" error.
>>> I avoided the problem by patching the AccessGrid files responsible for
>>> port allocation to keep a list
>>> of ports which are in use and have the allocation algorithm first check
>>> if a port the algorithm wants to allocate
>>> isn't in use yet.
>>> Otherwise you have to restart the bridge server until you don't get the
>>> "address already in use" error to be sure you really have
>>> video and audio correctly bridged.
>>> Michael
>>>> Thomas D. Uram said:
>>>>> Which version of AG software are you using for BridgeServer and
>>>>> VenueServer?
>>>>> Can you post your full bridge cfg file?
>>>> AG 2.4. Attached is the config file. Worth noted is that I no longer
>>>> get
>>>> those python errors, however, now when I start it, several of the
>>>> venues
>>>> aren't bridged because the bridgeserver says the address is already in
>>>> use
>>> Dipl.-Inf. Michael Braitmaier
>>> HLRS - Visualization / Video Conferencing
>>> University of Stuttgart
>>> Germany
>>> Phone: ++49 711 685 5996
>>> Fax  : ++49 711 682 357
>>> Website: http://www.hlrs.de/people/braitmaier/
