[AG-TECH] Bridge server
Thomas D. Uram
turam at mcs.anl.gov
Wed Apr 19 10:28:16 CDT 2006
Jeremy:
The portMin/portMax options have to follow each of the venue sections.
For example,
[venueUrl]
type = Venue
portMin = 30000
portMax = 30004
In your config file, portMin and portMax precede the venue sections.
Tom
On 4/19/06 9:06 AM, Jeremy Mann wrote:
> So basically I have to manually bridge each room. In my config file I
> tried to set the entire VenueServer to only use a range of ports, then I
> entered ports for the rooms I wanted to configure statically. But I still
> came across that "Address already in use" problem.
> For example, I have the VenueServer set to 5000-5200 and 4 Venues to 5202
> on up.
> Michael Braitmaier said:
>> I am doing basically the same. I restrict the range of the ports for
>> unicast for a specific venue.
>> Config-File example:
>> [https://rusagvideo.rus.uni-stuttgart.de:8000/Venues/000001026deebc1400c0006c00230006555]
>> type=Venue
>> portMin=50096
>> portMax=50099
>> One of the problems rising with this configuration method is that
>> normally AG selects ports on a random
>> pattern put of the range you specified in the config file.
>> Ports for rat and vic are allocated sequentially.
>> So first rat gets assigned 50096 for example.
>> When the port for vic should be determined, it can happen due to the
>> nature of the random allocation
>> that for vic also 50096 is initially selected. This of course leads to a
>> "Address already in use" error.
>> I avoided the problem by patching the AccessGrid files responsible for
>> port allocation to keep a list
>> of ports which are in use and have the allocation algorithm first check
>> if a port the algorithm wants to allocate
>> isn't in use yet.
>> Otherwise you have to restart the bridge server until you don't get the
>> "address already in use" error to be sure you really have
>> video and audio correctly bridged.
>> Michael
>> Jeremy Mann schrieb:
>>> Thomas D. Uram said:
>>>> Which version of AG software are you using for BridgeServer and
>>>> VenueServer?
>>>> Can you post your full bridge cfg file?
>>> AG 2.4. Attached is the config file. Worth noted is that I no longer get
>>> those python errors, however, now when I start it, several of the venues
>>> aren't bridged because the bridgeserver says the address is already in
>>> use
>> Dipl.-Inf. Michael Braitmaier
>> HLRS - Visualization / Video Conferencing
>> University of Stuttgart
>> Germany
>> Phone: ++49 711 685 5996
>> Fax : ++49 711 682 357
>> Website: http://www.hlrs.de/people/braitmaier/
