[AG-TECH] Node Services under windows
Derek Piper
dcpiper at indiana.edu
Wed Apr 19 09:19:30 CDT 2006
Ah, okay.. that's good to know :)
Thomas D. Uram wrote:
> I can confirm that. As of 2.3, I believe, agpm.py could also install
> node services.
> On 4/19/06 8:39 AM, Michael Braitmaier wrote:
>> As far as I know, agpm.py can be used for SharedApplications and
>> NodeServices as well. See the descriptiopn of usage of the agpm.py file:
>> "By default this program registers/installs a shared application
>> or node service with the users environment. Using the -u argument
>> applications
>> can be unregistered/uninstalled. To unregister node services, use
>> the '--unregister-service' argument."
>> Michael
>> Derek Piper schrieb:
>>> I thought that 'agpm.py' was for Shared Applications...
>>> For node services, the unpacked zip file needs to go in the
>>> 'NodeServices' directory where the toolkit resides, i.e.
>>> C:\Programs and Files\AGTk-2.4\NodeServices\
>>> It's possible it may be able to go into the User's 'NodeServices'
>>> directory in their 'Application Data' area.
>>> e.g.
>>> C:\Documents and Settings\<user>\Application
>>> Data\AccessGrid\NodeServices
>>> Then in order to actually use the service it must be added within the
>>> node configuration 'Manage My Node' and with the appropriate service
>>> manager, you go to 'Add Service' and it should show up.
>>> Now it's possible that what I described was a more 'manual'
>>> installation.. I don't know, but it's worked for me.
>>> Derek
>>>> Bonnett, PG (Paul) schrieb:
>>>>> Can anyone tell me how to install node services under Windows XP
>>>>> for AG Toolkit 2.3 or 2.4?
>>>>> I'm trying to run AG Device Control but in their documentation it
>>>>> says:
>>>>> 3. Download the node service zip
>>>>> <http://agcentral.org/downloads/agdevicecontrol/releases/0.5.2>
>>>>> from AGCentral. Install this ... however Windows users install node
>>>>> services???
>>>> You use the agpm.py script from the AccessGrid program folder.
>>>> agpm.py -z <put name of zip-file here>.zip
>>>> This should install the service on your windows machine, assuming
>>>> AccessGrid has been installed in advance
>>>> Michael
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
