[AG-TECH] Node Services under windows
Thomas D. Uram
turam at mcs.anl.gov
Wed Apr 19 09:17:22 CDT 2006
I can confirm that. As of 2.3, I believe, agpm.py could also install node
services.
On 4/19/06 8:39 AM, Michael Braitmaier wrote:
> As far as I know, agpm.py can be used for SharedApplications and
> NodeServices as well. See the descriptiopn of usage of the agpm.py file:
> "By default this program registers/installs a shared application
> or node service with the users environment. Using the -u argument
> applications
> can be unregistered/uninstalled. To unregister node services, use
> the '--unregister-service' argument."
> Michael
> Derek Piper schrieb:
>> I thought that 'agpm.py' was for Shared Applications...
>> For node services, the unpacked zip file needs to go in the
>> 'NodeServices' directory where the toolkit resides, i.e.
>> C:\Programs and Files\AGTk-2.4\NodeServices\
>> It's possible it may be able to go into the User's 'NodeServices'
>> directory in their 'Application Data' area.
>> e.g.
>> C:\Documents and Settings\<user>\Application Data\AccessGrid\NodeServices
>> Then in order to actually use the service it must be added within the
>> node configuration 'Manage My Node' and with the appropriate service
>> manager, you go to 'Add Service' and it should show up.
>> Now it's possible that what I described was a more 'manual'
>> installation.. I don't know, but it's worked for me.
>> Derek
>>> Bonnett, PG (Paul) schrieb:
>>>> Can anyone tell me how to install node services under Windows XP for
>>>> AG Toolkit 2.3 or 2.4?
>>>> I'm trying to run AG Device Control but in their documentation it says:
>>>> 3. Download the node service zip
>>>> <http://agcentral.org/downloads/agdevicecontrol/releases/0.5.2> from
>>>> AGCentral. Install this ... however Windows users install node
>>>> services???
>>> You use the agpm.py script from the AccessGrid program folder.
>>> agpm.py -z <put name of zip-file here>.zip
>>> This should install the service on your windows machine, assuming
>>> AccessGrid has been installed in advance
>>> Michael
