[AG-TECH] Bridge server
    Thomas D. Uram
    turam at mcs.anl.gov
    Tue Apr 18 13:23:31 CDT 2006
Which version of AG software are you using for BridgeServer and VenueServer?
Can you post your full bridge cfg file?
Tom
On 4/18/06 10:56 AM, Jeremy Mann wrote:
> I have moved the VenueServer port range out. However, restarting the
> bridge, the rest of rooms bridge into the port range I give, however the
> venues that I hardcoded I get this error:
> Exception in thread RunQueueThread:
> Traceback (most recent call last):
>   File "/usr/lib/python2.4/threading.py", line 442, in __bootstrap
>     self.run()
>   File "/usr/lib/python2.4/threading.py", line 422, in run
>     self.__target(*self.__args, **self.__kwargs)
>   File "/usr/bin/BridgeServer.py", line 617, in RunQueueThread
>     self.__AddBridge(event[1])
>   File "/usr/bin/BridgeServer.py", line 564, in __AddBridge
>     self.venuePortConfig["portMax"])
>   File
> "/mnt/scratch/AG2/AccessGrid-2.4/dist-20050828_120822/lib/python2.4/site-packages/AccessGrid/NetworkAddressAllocator.py",
> line 70, in AllocatePortInRange
> NoFreePortsError
> Thomas D. Uram said:
>> Hi Jeremy:
>> The portMin and portMax options are not used for VenueServer sections
>> in the config file.  You can specify portMin and portMax in the
>> BridgeServer
>> section to have it apply generally, and then specify particular ranges for
>> individual venues.
>> If you run into any problems with this, let us know.
>> Tom
>> On 4/18/06 10:41 AM, Jeremy Mann wrote:
>>> I need someone to tell me if I can do this with the Bridge server. I
>>> have
>>> several Venues that I want to hardcode the unicast port, the rest I want
>>> to let the BridgeServer assign. In my BridgeServer config file I have:
>>> #the main venueserver
>>> [https://ag1.v19.uthscsa.edu:8000/VenueServer]
>>> portMin = 30024
>>> portMax = 30050
>>> type = VenueServer
>>> # Lobby
>>> [https://ag1.v19.uthscsa.edu:8000/Venues/00000108b4cfc7360081006f004500a71d3]
>>> portMin = 30000
>>> portMax = 30002
>>> type = Venue
>>> and the rest of the rooms I want to assign....
>>> When I restarted the bridgeserver it didn't use the ports I assigned. Am
>>> I
>>> missing someething?
