[AG-TECH] Doorbell for the grid?
Tom Coffin
tcoffin at ncsa.uiuc.edu
Thu Apr 13 10:20:53 CDT 2006
Still, you may find a visual cue to be more effective
than and audio cue in such a noisy environment. Since you
already are using multiple monitors a couple more showing
the vic interface and a few important (persistent) video
windows may do the trick. If the existing layout of monitors
etc. is cluttered, you may want to consider implementing a
cluster of lcd panels to organize things, then 2-3 of those
could be allocated to AG video.
__________________________________________
At 10:51 AM 4/13/2006, Brian Tieman wrote:
>Tom,
>Hehe--you've obviously never worked at a synchrotron! The area where
>people generally sit is a cluttered messs of comuters and
>electronics--wires and monitors cover most--if not all--available wall space.
>We currently use headphones for the audio as echo cancelation is not cost
>effective or likely to work well in such a noisy environment (it can top
>60db white noise at times). I do not believe there is any practical way
>to use the AG audio channel for getting someones attention.
>Brian
>Tom Coffin wrote:
>>Are there any/some wall/screen spaces where projections can be used
>>at a scale significant enough to attract your attention while at
>>work on the beamline equipment?
>>At 08:29 AM 4/13/2006, Brian Tieman wrote:
>>>The beamline is a noisy place where people are focused on their experiments
>>___________________________________________________________
>>Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
>> NCSA-ACCESS cel: 703-477-5948
>> 901 North Stuart Street, #800 tel: 703-248-0105
>> Arlington, Virginia 22203 fax: 703-248-0100
>>_________________________ http://www.ncsa.uiuc.edu/~tcoffin
