[AG-TECH] Ag 2.4 Build for Suse 10
Jeremy Mann
jeremy at biochem.uthscsa.edu
Tue Apr 11 15:11:41 CDT 2006
I haven't a clue how to build a i586 RPM on this 64bit machine. I'm trying
to find Steven's 64bit code, but all I'm coming across is an old blog. You
have a direct link to the code?
Thanks!
Douglas Kosovic said:
> I should have added pyGlobus to the above list.
> compat-AccessGrid-2.4 needs to be built and installed last. pyGlobus
> after globus-accessgrid and python-SOAPpy after python-fpconst.
> I wouldn't worry too much about the build order as the BuildRequires in
> the spec files will let you know if a build dependency isn't getting
> satisfied when you try to rpmbuild each of the RPMs.
> I should also mention that AccessGrid-rat-4.2.22-*cvs*.src.rpm (i.e. ANL
> CVS rat) can only be built as a 32bit RPM, it might be able to be built
> by setting the rpmbuild --target arch argument to i586 (or however 32bit
> RPMs get built on Suse x86-64). If it doesn't want to get built as
> 32bit, you may need to build rat on a 32bit Suse instead.
> There is also a 64bit clean
> AccessGrid-rat-4.2.22-20051206darcs.*.src.rpm (i.e from Steve Smiths
> darcs repository) which would build as either 32bit or 64bit. The 32bit
> built rat seems to have less glitches than the 64bit.
> Cheers,
> Doug.
Jeremy Mann
University of Texas Health Science Center
Bioinformatics Core Facility
http://www.bioinformatics.uthscsa.edu
Phone: (210) 567-2672
