[AG-TECH] RAT over wireless
    Fred Dech
    fdech at uchicago.edu
    Tue Apr 11 12:05:45 CDT 2006
Hi Piers.
The wireless network quality isn't so good.  I'll need to check with them
about exactly what their reception quality matrix looks like.  They have
monitored the network and  have observed significant packet loss.
So, maybe redundancy would improve things.  I'll ask them to enable it.
Thanks.
--fred
On Tue, Apr 11, 2006 at 12:44AM, Piers O'Hanlon said:
> Hi
> > I've got a collaborator running into problems with  RAT point-to-point
> > tests over a wireless grid network.  I don't see that the 2 systems they
> > are using are an issue, since they are standard PCs and there are no RAT
> > audio problems over their regular networks.
> RAT runs fine over Wireless unless there's a lot of loss - do you see
> loss of packets over the wireless? (check the reception quality
> matrix). If you're seeing loss you could try enabling rendundancy in
> menu->transmission. Typically a 802.11b or g or less are fine. If
> you;re using multicast there may be issues due to the AP - though it
> usually works ok on most APs unless there's alot of multicast.
> Piers.
> > There's apparently enough latency, jitter, packet-loss over the wireless
> > network to cause RAT audio to cut in and out.  I checked with them to
> > make sure that silence suppression is disabled.  It is, so that isn't
> > contributing to the problem.
> > Are there any less-obvious RAT configuration changes that may help decrease
> > audio breakup over this lower than spec network?  No VICs are being run in
> > their current testing.
> > Thanks.
> > --fred
