[AG-TECH] RAT over wireless
Brian Corrie
bcorrie at sfu.ca
Mon Apr 10 19:23:15 CDT 2006
I use AG over wireless quite often, with both audio and video. It works
fine for the most part. If there are problems I would hazard a guess
that it is a wireless network issue. Either lots of wireless traffic,
overloaded Access Points (too many connections) and/or poor signal
strength for the wireless (too far from an AP).
Brian
Piers O'Hanlon wrote:
> Hi
>> I've got a collaborator running into problems with RAT point-to-point
>> tests over a wireless grid network. I don't see that the 2 systems they
>> are using are an issue, since they are standard PCs and there are no RAT
>> audio problems over their regular networks.
> RAT runs fine over Wireless unless there's a lot of loss - do you see
> loss of packets over the wireless? (check the reception quality
> matrix). If you're seeing loss you could try enabling rendundancy in
> menu->transmission. Typically a 802.11b or g or less are fine. If
> you;re using multicast there may be issues due to the AP - though it
> usually works ok on most APs unless there's alot of multicast.
> Piers.
>> There's apparently enough latency, jitter, packet-loss over the wireless
>> network to cause RAT audio to cut in and out. I checked with them to
>> make sure that silence suppression is disabled. It is, so that isn't
>> contributing to the problem.
>> Are there any less-obvious RAT configuration changes that may help decrease
>> audio breakup over this lower than spec network? No VICs are being run in
>> their current testing.
>> Thanks.
>> --fred
