[AG-TECH] RAT over wireless
    Piers O'Hanlon
    p.ohanlon at cs.ucl.ac.uk
    Mon Apr 10 18:44:56 CDT 2006
Hi
> I've got a collaborator running into problems with  RAT point-to-point
> tests over a wireless grid network.  I don't see that the 2 systems they
> are using are an issue, since they are standard PCs and there are no RAT
> audio problems over their regular networks.
RAT runs fine over Wireless unless there's a lot of loss - do you see
loss of packets over the wireless? (check the reception quality
matrix). If you're seeing loss you could try enabling rendundancy in
menu->transmission. Typically a 802.11b or g or less are fine. If
you;re using multicast there may be issues due to the AP - though it
usually works ok on most APs unless there's alot of multicast.
Piers.
> There's apparently enough latency, jitter, packet-loss over the wireless
> network to cause RAT audio to cut in and out.  I checked with them to
> make sure that silence suppression is disabled.  It is, so that isn't
> contributing to the problem.
> Are there any less-obvious RAT configuration changes that may help decrease
> audio breakup over this lower than spec network?  No VICs are being run in
> their current testing.
> Thanks.
> --fred
