[AG-TECH] Setting web proxy for AG2 ?
    Thomas D. Uram
    turam at mcs.anl.gov
    Mon Apr  3 12:52:32 CDT 2006
You should only need to set the web proxy for requesting certificates, which can
be done directly in the certificate request tool.  If you're having a
particular problem
getting started, you can submit a bug report (from the Help menu) which will
include
relevant portions of the AG logfiles so we can understand the problem.
Tom
On 3/30/06 8:12 AM, Thierry Delaitre wrote:
> Hi,
> I've installed AG2 under windows & MACOSX and was wondering how to set the
> web proxy for connecting to a venue server ? Our university does not have
> a transparent web proxy and we need to specify the url of the web proxy
> for applications otherwise applications like AG2 cannot contact web
> servers directly.
> I tried to set the http_proxy env var under Windows but to no avail. Any
> help would be grately appreciated.
> Thanks,
> Dr Thierry DELAITRE
> Systems and Services Manager, CSCS
> University of Westminster
> 115 New Cavendish Street, London W1W 6UW
> Tel: 020 7911 5000 ext: 3586
> Fax: 020 7911 5089
> Mobile short dial code 1788
> http://www.cscs.wmin.ac.uk/~delaitt
> This e-mail and its attachments are intended for the above named only
> and may be confidential.  If they have come to you in error you must
> not copy or show them to anyone, nor should you take any action based
> on them, other than to notify the error by replying to the sender.
