[AG-TECH] Fedora Core 64bit
Douglas Kosovic
douglask at itee.uq.edu.au
Fri Sep 16 19:40:17 CDT 2005
Hi Jim,
> I was pointed to some excellent docs on getting the Access grid
> software installed on a Fedora Core 4 system.
> The system I am working with is a FC4 x86_64.
> I have gotten the pre-built 32bit rpms installed. The problem I have
> encountered is the portion of the install where wxmozilla must be
> rebuilt.
And the 32bit AGTk RPMs work? I'm a bit surprised as x86-64 FC4's 64bit
Python need 64bit Python modules installed in
/usr/lib64/python2.4/site-packages. Did you install the 32bit python
from i386 FC4?
> So I wasn't sure which to pursue,
> 1. get wxmozilla built for 32bit on this 64bit system.
> or
> 2. get whatever is in the 32bit that it is looking for built for
> 64bit.
For building 32bit wxmozilla, you could try:
rpmbuild --target=i386 --rebuild wxmozilla*.src.rpm
But you will need to have all the 32bit RPMs that wxmozilla
directly/indirectly depends on and links against, including Mozilla,
which could end up being a bit messy.
You can't mix 32bit libraries with 64bit in the same application.
Cheers,
Doug
