[AG-TECH] problem importing cert from .pem file, AGTk2.4 on OSX10.4
Thomas D. Uram
turam at mcs.anl.gov
Thu Sep 1 15:51:25 CDT 2005
Hi David:
This is a problem in wxPython2.6 on OSX. As you've probably seen from the bug you
reported, the fix is in cvs; I plan to release an update before long that will include
this fix.
Meanwhile, the workaround is to use the anonymous certificate that you mentioned.
If the venue client crashed, you can see a stack trace in
~/Library/Logs/CrashReporter/Python.crash.log. We've seen some instability with wxPython
still; I'd be curious if it appears in your crash log.
Tom
David McNabb wrote:
> Good morning.
> I just installed AGTk10.4 with new wxPython2.6-osx-unicode-2.6.1.0-
> macosx10.3-py2.3 followed by TigerPython23Compat on my OSX10.4 G5
> tower/isight/iMic-USB. The Venue Client would not accept my old cert
> passphrase. I deleted that cert (an anon cert automagically appeared) and then
> tried to re-import my cert from my .pem file (using the certmanager selected
> from venue client menu.) The Venue Client crashed after I hit import and while
> the enter passphrase window was up. (See attached log from system report.)
> Same problem using launcher->cert manager.
> This report plus log files have been submitted via bugzilla.
> --David
> David McNabb
> Project Lead, UMAGI
> UM Access Grid Initiative
> Middleware and Grid Initiative
> Enterprise Internet Services
> Office of Information Technology
> University of Maryland
> College Park, MD, USA
> mcnabb at umd.edu
