[AG-TECH] ANL bridge machine and port info?
    Derek Piper
    dcpiper at indiana.edu
    Mon Oct 31 07:30:38 CST 2005
	How would I go about running the server on its own? The binary that
comes with the AGConnector package complains about being run incorrectly
but doesn't give any useful information. I'm having trouble finding a
UMTP server that I can run on a central machine. I'm modifying the
AGConnector python script to have this machine as the default, so people
should be able to run it without configuring a new server.
	Derek
Thomas D. Uram wrote:
> Hi Derek:
> Comments inline...
> On 10/27/05 8:55 AM, Derek Piper wrote:
>>     Hi Tom,
>>     I tried playing with AGConnector, does it have to go to just your
>> server there? Is it possible to run a server on a local machine and
>> have other clients connect to it? Like the local bridge, but simpler?
> The default server is the one here at ANL (umtp.mcs.anl.gov).  AGConnector
> does allow you to specify which server to use, so yes:  if you have a
> UMTP server running, you can specify it in AGConnector and it will be
> used instead.  In fact, in the future I'd like to see umtp servers
> proliferate
> and be discoverable.
> I also
>> have a question about how it works too, in trying to test it on two
>> machines that are on a LAN (and so have full visibility of each other
>> wrt multicast) I didn't notice any difference - should I? ..
> UMTP is a solution for people who have no multicast, and it actually
> shuts down if it receives a packet from itself over multicast (see
> the ietf UMTP draft).
>  I'm trying
>> to test it so I know what I'm doing with it to help a remote site with
>> their AG connection. Actually, I'm wanting it for helping someone at
>> Argonne / University of Chicago combat the draconian firewalling :)
>>     Derek
>>> I'd recommend that you look at the AGConnector shared app.  It does
>>> everything over
>>> a single, fixed port (8010) to a server here at ANL
>>> (umtp.mcs.anl.gov).  No port range
>>> needed, and coverage for every venue, not just those that people
>>> chose to bridge.
>>> Tom
>>> On 10/26/05 12:36 PM, Julia Mullen wrote:
>>>> Hi -
>>>> I'm trying to get the okay to open ports so that I can attend the Town
>>>> Halls, and any
>>>> other events on the ANL venue server, so I need some information re:
>>>> the bridge server IP and ports.  Is there a document, or easy way to
>>>> get the list of bridged ANL venues, and the
>>>> bridge IP address, as well as the range of ports for the bridge. . .
>>>> yup, a continuation of the Security Office's questions.
>>>> Thanks -
>>>>   Julie
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
