[AG-TECH] encryption protocols
    Andrew A Rowley
    Andrew.Rowley at manchester.ac.uk
    Fri Oct 28 08:11:26 CDT 2005
InSORS definitely supports at least the DES standard.  To make this work, I would guess that if you are going to use the AGTk automatic distribution of the key, you will need to set the key manually in the Venue Management console.  This will then have to use DES encryption to guarantee interoperability i.e. specify the key as DES/<key>.  At the InSORS key prompt, just enter the <key> part.
It is probably easier to just enter the key into the vic and rat encryption boxes manually (see http://www.agsc.ja.net/faqs.php#Q6).
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Julia Mullen [mailto:julia.mullen at gmail.com]
> Sent: 28 October 2005 14:02
> To: Andrew.Rowley at manchester.ac.uk
> Cc: Thomas D. Uram; ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] encryption protocols
> Hi -
> I am not sure what protocol inSORS uses, but I do know that we can
> encrypt mixed platform meetings - when an inSORS client attempts to
> enter a venue where there are encrypted sites, you are asked for a
> 'key' (this is when you enter via the taskbar tools, not the webpage,
> I haven't used the web based connection method) - for inSORS, when you
> submit the key it encrypts both audio and video at the same time.
> This is the only way that I have found for encrypting mixed inSORS/AG
> meetings, and I did spend a good bit of time pursuing this.  We have a
> monthly encrypted mixed platform meeting and I was asked recently
> about the protocols - thus the initial email.
> Thanks,
>   Julie
> On 10/28/05, Andrew A Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> > Hi,
> > I am not sure if InSORS software supports Rijndael/AES though - a quick
> test just now suggests that it doesn't...
> > Andrew :)
> > RSS Group,
> > Kilburn Building,
> > Oxford Road,
> > Manchester,
> > M13 9PL,
> > UK
> > > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> > > Behalf Of Thomas D. Uram
> > > Sent: 27 October 2005 16:38
> > > Cc: Julia Mullen; ag-tech at mcs.anl.gov
> > > The AG venue management software allows admins to specify the key to
> be
> > > used
> > > for a venue.  In the absence of
> > > a user-specified key, for an encrypted venue, the venue server will
> > > allocate a
> > > key in the form 'Rijndael/key', and
> > > so is relying on Rijndael/AES by default.
> > > Tom
> > > On 10/27/05 4:51 AM, Andrew A Rowley wrote:
> > > > Hi,
> > > > The default RTP encryption is the DES standard.  This is used by vic
> and
> > > rat if you do not enter any other standard (you enter a key as
> > > <standard>/<key>, but if you just enter <key>, you will get DES).  I
> think
> > > that some support has been added for AES (or rijindael) encryption,
> but I
> > > don't know if this works.
> > > > Andrew :)
> > > > RSS Group,
> > > > Kilburn Building,
> > > > Oxford Road,
> > > > Manchester,
> > > > M13 9PL,
> > > > UK
> On
> > > >>Behalf Of Julia Mullen
> > > >>Sent: 26 October 2005 17:36
> > > >>To: ag-tech at mcs.anl.gov
> > > >>Subject: [AG-TECH] encryption protocols
> > > >>Hi -
> > > >>The security folks here at Lincoln are wondering what protocols we
> use
> > > >>for encryption -
> > > >>in those instances when we encrypt audio and video.  Can anyone tell
> > > >>me - or point me
> > > >>to the appropriate document?
> > > >>Many thanks,
> > > >>   Julie
