[AG-TECH] encryption protocols
    Julia Mullen
    julia.mullen at gmail.com
    Fri Oct 28 08:01:55 CDT 2005
Hi -
I am not sure what protocol inSORS uses, but I do know that we can
encrypt mixed platform meetings - when an inSORS client attempts to
enter a venue where there are encrypted sites, you are asked for a
'key' (this is when you enter via the taskbar tools, not the webpage,
I haven't used the web based connection method) - for inSORS, when you
submit the key it encrypts both audio and video at the same time.
This is the only way that I have found for encrypting mixed inSORS/AG
meetings, and I did spend a good bit of time pursuing this.  We have a
monthly encrypted mixed platform meeting and I was asked recently
about the protocols - thus the initial email.
  Julie
On 10/28/05, Andrew A Rowley <Andrew.Rowley at manchester.ac.uk> wrote:
> Hi,
> I am not sure if InSORS software supports Rijndael/AES though - a quick test just now suggests that it doesn't...
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> > Behalf Of Thomas D. Uram
> > Sent: 27 October 2005 16:38
> > To: Andrew.Rowley at manchester.ac.uk
> > Cc: Julia Mullen; ag-tech at mcs.anl.gov
> > Subject: Re: [AG-TECH] encryption protocols
> > The AG venue management software allows admins to specify the key to be
> > used
> > for a venue.  In the absence of
> > a user-specified key, for an encrypted venue, the venue server will
> > allocate a
> > key in the form 'Rijndael/key', and
> > so is relying on Rijndael/AES by default.
> > Tom
> > On 10/27/05 4:51 AM, Andrew A Rowley wrote:
> > > Hi,
> > > The default RTP encryption is the DES standard.  This is used by vic and
> > rat if you do not enter any other standard (you enter a key as
> > <standard>/<key>, but if you just enter <key>, you will get DES).  I think
> > that some support has been added for AES (or rijindael) encryption, but I
> > don't know if this works.
> > > Andrew :)
> > > RSS Group,
> > > Kilburn Building,
> > > Oxford Road,
> > > Manchester,
> > > M13 9PL,
> > > UK
> > >>Behalf Of Julia Mullen
> > >>Sent: 26 October 2005 17:36
> > >>To: ag-tech at mcs.anl.gov
> > >>Subject: [AG-TECH] encryption protocols
> > >>Hi -
> > >>The security folks here at Lincoln are wondering what protocols we use
> > >>for encryption -
> > >>in those instances when we encrypt audio and video.  Can anyone tell
> > >>me - or point me
> > >>to the appropriate document?
> > >>Many thanks,
> > >>   Julie
