[AG-TECH] AGTK pyglobus error
    Steven
    s.jack at compserv.gla.ac.uk
    Thu Oct 13 06:17:38 CDT 2005
Swig is version 1.3.25
I have set GPT_LOCATION and GLOBUS_LOCATION to /usr/lib/gpt-3.1
devpython is 2.4.1-r1
The data management client looks as though it is successfully built as part
of the AG install at version 2.4.3-r2.
There is no additional Globus software.
I have attached the tail end of the emerge log file.
Thanks for the help
Steven
-----Original Message-----
Sent: 11 October 2005 15:18
To: Steven
Cc: Ag-Tech
Subject: Re: [AG-TECH] AGTK pyglobus error
Hi Steven:
Do you have the Globus data management client package installed that's a
prereq
for the AG software?
Do you have any additional globus software installed?
Which version of swig?
The AG toolkit doesn't require gassCache, gassServerEZ, myproxy, gramClient,
or
rlsClient, so it does
not build the pyGlobus support for them.  (There is a 'clean' step, in which
it
will report building or having built
all of the modules.)
If you have a log of the emerge, that might also be helpful.
Tom
On 10/11/05 4:25 AM, Steven wrote:
> Hi I am having problems installing AGTK2.4 on Gentoo 2.6.12-r6
> It fails to compile the pyGlobus code complaining SWIGTYPE_p_Globus_byte_t
> is undeclared. It complains earlier complaining the dependency to build
> gassCache package, same for gassServerEZ, myProxy, gramClient and
rlsClient
> Any help appreciated.
> Thanks
> /usr/include/bits/stdio_lim.h:40:1: warning: this is the location of the
> previous definition
> src/ftpClient_wrap.c: In function `PythonDataCallback':
> src/ftpClient_wrap.c:1563: error: `SWIGTYPE_p_globus_byte_t' undeclared
> (first use in this function)
> src/ftpClient_wrap.c:1563: error: (Each undeclared identifier is
> reported only once
> src/ftpClient_wrap.c:1563: error: for each function it appears in.)
> src/ftpClient_wrap.c: In function `PythonPluginRead':
> src/ftpClient_wrap.c:2193: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginMove':
> src/ftpClient_wrap.c:2226: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginList':
> src/ftpClient_wrap.c:2258: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginSize':
> src/ftpClient_wrap.c:2290: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginVerboseList':
> src/ftpClient_wrap.c:2322: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginRmdir':
> src/ftpClient_wrap.c:2354: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginMkdir':
> src/ftpClient_wrap.c:2386: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginModificationTime':
> src/ftpClient_wrap.c:2418: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginData':
> src/ftpClient_wrap.c:2492: error: `SWIGTYPE_p_globus_byte_t' undeclared
> error: command 'i686-pc-linux-gnu-gcc' failed with exit status 1
> !!! ERROR: dev-python/pyglobus-0.9.7-r1 failed.
> !!! Function distutils_src_compile, Line 35, Exitcode 1
> !!! compilation failed
> Steven Jack
> Videoconferencing Manager
> University of Glasgow
> Computing Service
> Glasgow G12 8QQ
> UK
> Tel +44(0)1413303828 Fax +44(0)1413303820
> Email: s.jack at compserv.gla.ac.uk
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20051013/98695663/attachment.txt>
