[AG-TECH] AGTK pyglobus error
    Thomas D. Uram
    turam at mcs.anl.gov
    Tue Oct 11 09:17:37 CDT 2005
Hi Steven:
Do you have the Globus data management client package installed that's a prereq
for the AG software?
Do you have any additional globus software installed?
Which version of swig?
The AG toolkit doesn't require gassCache, gassServerEZ, myproxy, gramClient, or
rlsClient, so it does
not build the pyGlobus support for them.  (There is a 'clean' step, in which it
will report building or having built
all of the modules.)
If you have a log of the emerge, that might also be helpful.
Tom
On 10/11/05 4:25 AM, Steven wrote:
> Hi I am having problems installing AGTK2.4 on Gentoo 2.6.12-r6
> It fails to compile the pyGlobus code complaining SWIGTYPE_p_Globus_byte_t
> is undeclared. It complains earlier complaining the dependency to build
> gassCache package, same for gassServerEZ, myProxy, gramClient and rlsClient
> Any help appreciated.
> Thanks
> /usr/include/bits/stdio_lim.h:40:1: warning: this is the location of the
> previous definition
> src/ftpClient_wrap.c: In function `PythonDataCallback':
> src/ftpClient_wrap.c:1563: error: `SWIGTYPE_p_globus_byte_t' undeclared
> (first use in this function)
> src/ftpClient_wrap.c:1563: error: (Each undeclared identifier is
> reported only once
> src/ftpClient_wrap.c:1563: error: for each function it appears in.)
> src/ftpClient_wrap.c: In function `PythonPluginRead':
> src/ftpClient_wrap.c:2193: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginMove':
> src/ftpClient_wrap.c:2226: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginList':
> src/ftpClient_wrap.c:2258: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginSize':
> src/ftpClient_wrap.c:2290: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginVerboseList':
> src/ftpClient_wrap.c:2322: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginRmdir':
> src/ftpClient_wrap.c:2354: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginMkdir':
> src/ftpClient_wrap.c:2386: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginModificationTime':
> src/ftpClient_wrap.c:2418: error: `SWIGTYPE_p_globus_byte_t' undeclared
> src/ftpClient_wrap.c: In function `PythonPluginData':
> src/ftpClient_wrap.c:2492: error: `SWIGTYPE_p_globus_byte_t' undeclared
> error: command 'i686-pc-linux-gnu-gcc' failed with exit status 1
> !!! ERROR: dev-python/pyglobus-0.9.7-r1 failed.
> !!! Function distutils_src_compile, Line 35, Exitcode 1
> !!! compilation failed
> Steven Jack
> Videoconferencing Manager
> University of Glasgow
> Computing Service
> Glasgow G12 8QQ
> UK
> Tel +44(0)1413303828 Fax +44(0)1413303820
> Email: s.jack at compserv.gla.ac.uk
