[AG-TECH] Configuring and Running BridgeServer
Thomas D. Uram
turam at mcs.anl.gov
Tue Oct 11 10:18:57 CDT 2005
Hi Robert:
I see a couple things wrong:
- You have listed the url for the ORNL venue incorrectly in the config file.
It should be
https://ivs.mcs.anl.gov:9000/Venues/00000100ce34afd1008c00dd000a005a0b3
- The url for the venue server is also incorrect; it should be:
https://ivs.mcs.anl.gov:9000/VenueServer
though I'm not sure you intended to bridge the entire institutional venue
server, so maybe
this line was experimental.
- You will run into problems trying to run a bridgeserver on your video
machine. If QuickBridge is
running on that machine, it will be using ports that are needed by vic,
preventing it from even running;
the converse is also true.
Tom
On 10/11/05 9:54 AM, Johnston, Robert Bruce wrote:
> AG Tech,
> We are trying to implement BridgeServer and it does not seem to be
> working for us. To help explain our configuration I’ve attached both the
> configuration file and the BridgeServer log file. From a quick glance
> at the log file, it looks as if we have a Certificate problem but I’m
> not sure how to resolve it. Can you take a look and see if you have any
> ideas as to what we may be doing wrong? Here’s our configuration:
> We have a two CPU AG node located outside of our firewall which is
> currently running AG 2.3. The first machine is a Windows box for audio,
> display, and the Venue client. The second box is running Red Hat Linux
> Enterprise for video encoding and is the box we are trying to bring up
> the BridgeServer on. As our first test, we went to the ORNL venue,
> under “Government Instutitions” and recorded the venue URL, which is the
> URL we were using in the BridgeServer configuration file. We made the
> assumption that the BridgeServer was not working because we never got
> any feed back after issuing the command line and the Unicast option was
> never highlighted in the venue client. One other thing I probably
> should mention, the certificate is working fine with the Service Manager
> for the Video encoding service.
> Please let me know if you need any additional information to help
> define our problem.
> Thanks
> R. Bruce Johnston, johnstonrb at ornl.gov <mailto:johnstonrb at ornl.gov>
> Networking and Computing Technologies Division
> Oak Ridge National Laboratory
> Rm. J309-5, Bldg. 5600, MS-6018
> Phone: 865.574.8806 Fax: 865.241.6982
