[AG-TECH] AGTk on MacOS
    Eric Olson
    eolson at mcs.anl.gov
    Wed Oct  5 11:44:05 CDT 2005
Hi Charles,
You don't need to run the node setup wizard (runns.sh).  It is not
currently needed for anything (unless it somehow helps debugging).
 From the launcher (runag.sh):
- The only button really needed is Main->VenueClient
- You may first want to run Configuration->Node Setup Wizard, but don't
run it at the same time as the VenueClient.  Optionally, you can
accomplish the same things that the node setup wizard does by using node
management from the VenueClient menu: Preferences->Manage My Node...
- If you are using a multi-machine node, you can start a service manager
from Services->Service Manager.
I have seen other people run the node service recently, although it's
not needed (it would have been removed if we weren't trying to minimize
unnecessary changes for the 2.4 release) -- can you tell me if you found
this suggestion in the documentation somewhere, or if it's just not
clear in the user interface (very likely)?
The error you're getting is that there is no audio and video after you
connect.  I would suggest two things:
- Make sure you have audio and video services listed under
Preferences->Manage My Node.  To send video, you should remove the
VideoConsumer service and add the VideoService (which will "Produce" and
"Consume" video).
- Evaluate your network and firewall.  If you don't have multicast
networking. you'll need to use a bridge or the new AG Connector (still
being tested, but works very well).  To use a bridge, you'll need to
find a venue with bridges in it -- all venues in the Community Lobby are
bridged.  Selecting Preferences->"Use Unicast" is all you need to do.
If "Use Unicast" is greyed out, the current venue does not have a bridge.
Eric
Charles Nichols wrote:
> I'm unable to get AGTk 2.3 or 2.4 to run under Mac OS X.3.9 or OS X. 4.2
> on a PowerBook G4 1.67 or 800, even though everything installed
> successfully according to the instructions on the web page.
> These are the problems I'm having:
> for Services->Node Service
> I get the following exception:
> /Applications/AccessGridToolkit.app/Contents/MacOS/runns.sh; exit
> Welcome to Darwin!
> ss127music1:~ cnichols$ /Applications/AccessGridToolkit.app/Contents/
> Starting Node Service URL: https://10.8.23.30:11000/NodeService
> Starting Service Manager URL: https://10.8.23.30:11000/ServiceManager
> Starting Service URI: https://10.8.23.30:50119/Service
> Traceback (most recent call last):
>   File "/Applications/AccessGridToolkit.app/Contents/Resources/bin/
> AGServiceManager.py", line 147, in ?
>     main()
> AGServiceManager.py", line 132, in main
>     gNodeService.LoadDefaultConfig()
>   File "/Applications/AccessGridToolkit.app/Contents/Resources/lib/
> python2.3/site-packages/AccessGrid/AGNodeService.py", line 382, in
> LoadDefaultConfig
>     raise Exception("Failed to load default configuration <%s>" %
> Exception: Failed to load default configuration <defaultMac>
> for Configuration->Node Setup Wizard
> I input Display Machine Name but get "Could not connect.  Is a  service
> manager running at a given machine and port?"
> for Main->Venue Client
> I can enter the Lobby of https://vv2.mcs.anl.gov:9000/Venues/default
> and can see other participants listed and chat, but don't show up in
> the RAT of other participants, and don't hear audio or see video.
> -Charles
> Charles Nichols
> University of Montana
> Department of Music
> Missoula, MT  59812
> (406) 243-5360
> www.CharlesNichols.com
