[AG-TECH] Can't read proxy
Thomas D. Uram
turam at mcs.anl.gov
Tue Nov 22 10:13:47 CST 2005
Steven:
You could try running these commands with the '-d' option on the command-line,
which will dump additional debug information as it runs. This might help you
understand the problem. The additional information also appears in the related
log files (in ~/.AccessGrid/Logs); if you don't see a clear indication of the
problem
there, you can send the log file to me for a look.
Tom
On 11/22/05 2:54 AM, Steven wrote:
> Thanks Chris but it drops out of certmgr at the end returning to the Linux
> command prompt, sorry could have made that clearer.
> Steven
> -----Original Message-----
> From: Christoph Willing [mailto:willing at itee.uq.edu.au]
> Sent: 21 November 2005 22:03
> To: Steven
> Subject: Re: [AG-TECH] Can't read proxy
> On 22/11/2005, at 3:41 AM, Steven wrote:
>>Hi I have built AG2.4 on a Gentoo 2.6.12-r6 system. Running certmgr.py
>>results in the output below, where after some delay returns to the
>>command
>>prompt.
>>Running NodeSetupWizard.py, VenueClient.py, etc does much the same
>>before
>>bringing up the certificate request application, where after
>>cancelling or
>>completing this results in the application hanging.
>>The certificate files in the CAcertificates directory appear to be
>>okay
>>Any help appreciated.
> Steven,
> The "ERROR" responses are normal; in gereral, ignore them. When
> certmgr returns to the command prompt, type:
> for a list of possible commands. Your most common commands will be:
> list
> show <n>
> import <some_cert>
> chris
> Christoph Willing +61 7 3365 8350
> QPSF Access Grid Manager
> University of Queensland
