[AG-TECH] Changing Venue Server ports from default
Michael Miller
mimiller at ncsa.uiuc.edu
Tue May 24 10:45:09 CDT 2005
Jason,
Here's a snippet from our VenueServer.cfg file:
# AGTk 2.3
[VenueServer]
defaultVenue = 000000fe456540d8008d008e0040000bfa6
performanceReportFile =
dataStorageLocation = Data
venuePathPrefix = Venues
eventPort = 9002
serverPrefix = VenueServer
performanceReportFrequency = 0
encryptAllMedia = 0
addressMask = 17
addressAllocationMethod = random
dataPort = 9006
textPort = 9004
baseAddress = 224.2.128.0
houseKeeperFrequency = 300
persistenceFilename = VenueServer.dat
backupServer =
You can see where the event, text and data ports are set. The main port
is set with the -p option given to the VenueServer.py script.
Hope this helps
MYK
Jason Soohoo wrote:
> Hi all,
> We're looking to change our default port setting for our VenueServer.
> By default it is set for 8000, 8002, 8004, 8006. But our upper level
> network administration has blocked the 8000s due to a possible
> security threat. I know some servers host at port 9000. We'd like to
> change ours to do the same.
> Is there an easy way to change the default ports other than going into
> the code itself?
> Thank you all for your time,
> Jason SooHoo
