[AG-TECH] Changing Venue Server ports from default
Tom Uram
turam at mcs.anl.gov
Tue May 24 10:39:09 CDT 2005
Hi Jason:
You can change the ports as follows:
The main port for the venue server (for SOAP calls) is specified on the command line,
using the '-p' option. The other ports (for data, event, and text) are specified in the
VenueServer.cfg file, with the following options:
dataPort = <portnum>
textPort = <portnum>
eventPort = <portnum>
These options will be apparent if you look at your VenueServer.cfg file.
I've also filed a bug against the Venue Management manual, since this detail should be
included there (http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1312).
Tom
On 05/24/05 10:26, Jason Soohoo wrote:
> Hi all,
> We're looking to change our default port setting for our VenueServer.
> By default it is set for 8000, 8002, 8004, 8006. But our upper level
> network administration has blocked the 8000s due to a possible security
> threat. I know some servers host at port 9000. We'd like to change
> ours to do the same.
> Is there an easy way to change the default ports other than going into
> the code itself?
> Thank you all for your time,
> Jason SooHoo
