[AG-TECH] Can't connect to RCBridge
Rod Harris
rod.harris at anu.edu.au
Tue May 17 20:36:05 CDT 2005
Actually thats a problem with java using an ipv6 interface by default. You
can use the
-Djava.net.preferIPv4Stack=true
option (to the java executable) to get around this regardless of which
kernel you're using.
Rod
At 02:23 PM 17/05/2005, Markus Buchhorn wrote:
>Hi Natalia
>At 08:06 PM 16/05/2005 +0200, Natalia Costas Lago wrote:
> >I've read about RCBridge and it seems quite an interesting tool (mainly
> because the last 2h sesion we recorded was 2 GB in size, so some kind of
> streams selection method is needed).
>Our recording system has stream selection too :-) for that very reason.
> >I installed the software (java and so).. and i can connect from a client
> by means of a web browser, but problems arise when the bridge is to be
> created:
> >UdpListener error: Failed to create socket: Cannot assign requested
> address: 239.194.100.100/1234
> >UdpBridge Error: Couldn't create UdpBridge from /239.194.100.100:1234 to
> /193.144.36.152:17306
> >Client: couldn't make Rtp/Rtcp Bridges
>Ah, you're probably on a 2.6 kernel system. Sorry - there's an updated
>version I can point you to which fixes this, but I'm out of the office
>right at the moment - Rod, can you please point Natalia to it? (I need to
>update the rcbridge webpage, <sigh> and the rest)
>Cheers,
> Markus
>Markus Buchhorn, ANU Internet Futures |Ph: +61 2 61258810
>Markus.Buchhorn at anu.edu.au |Fx: +61 2 61259805
>The Australian National University, Canberra 0200 |Mob: 0417 281429
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050518/089e7e36/attachment.htm>
