[AG-TECH] Can't connect to RCBridge
Markus Buchhorn
Markus.Buchhorn at anu.edu.au
Mon May 16 23:23:28 CDT 2005
Hi Natalia
At 08:06 PM 16/05/2005 +0200, Natalia Costas Lago wrote:
>I've read about RCBridge and it seems quite an interesting tool (mainly because the last 2h sesion we recorded was 2 GB in size, so some kind of streams selection method is needed).
Our recording system has stream selection too :-) for that very reason.
>I installed the software (java and so).. and i can connect from a client by means of a web browser, but problems arise when the bridge is to be created:
>UdpListener error: Failed to create socket: Cannot assign requested address: 239.194.100.100/1234
>UdpBridge Error: Couldn't create UdpBridge from /239.194.100.100:1234 to /193.144.36.152:17306
>Client: couldn't make Rtp/Rtcp Bridges
Ah, you're probably on a 2.6 kernel system. Sorry - there's an updated version I can point you to which fixes this, but I'm out of the office right at the moment - Rod, can you please point Natalia to it? (I need to update the rcbridge webpage, <sigh> and the rest)
Cheers,
Markus
Markus Buchhorn, ANU Internet Futures |Ph: +61 2 61258810
Markus.Buchhorn at anu.edu.au |Fx: +61 2 61259805
The Australian National University, Canberra 0200 |Mob: 0417 281429
