[AG-TECH] Re: [AG-L] Installing AccessGrid on a 64bit machine
    Douglas Kosovic
    douglask at itee.uq.edu.au
    Tue May 10 00:17:28 CDT 2005
Hi Ashley,
> I am trying to install AccessGrid on a AMD Opteron 64 machine. The machine
> is running RedHat EL 4 WS.
> When I try to install wxGTK2, I get some failed dependencies:
> libgtkembedmoz.so & libxpcom.so. I know these are provided by mozilla or
> firefox. However I am using the 64bit versions (as provided by Red Hat). I
> can see that the files are in /usr/lib64/mozilla-1.7.7/. I am assuming
> that the rpms are looking for the packages in /usr/lib/.
> Does anybody know how to solve this?
I assume you are using the x86-64 FC3 RPMs from:
http://www.itee.uq.edu.au/~agn/ag_fedora/FC3/stable/RPMS/x86_64/
The problem is probably with wxMozilla, you don't need to intall that unless
you want to run the SharedBrowser. If you want to intall it:
wget
http://www.itee.uq.edu.au/~agn/ag_fedora/FC3/stable/SRPMS/wxmozilla-0.5.3-1.src.rpm
rpmbuld --rebuild wxmozilla-0.5.3-1.src.rpm
rpm -i /usr/src/redhat/RPMS/x86_66/wxmozilla-0.5.3-2.x86_64.rpm
rpm -i /usr/src/redhat/RPMS/x86_66/wxmozilla-python-0.5.3-2.x86_64.rpm
You could also try the x86-64 Fedora Extras wxGTK2* and wxPythonGTK2 RPMs
on:
http://fedoraproject.org/extras/3/x86_64/
The wx* RPMs (except for wxMozilla) on my site are slightly modified for
x86_64 and rebuilt versions of the Fedora Extras 2 RPMs, it's because at the
time I created them, the Fedora Extras 3 RPMs weren't available.
Cheers,
Doug
