[AG-TECH] Venue server using LAN
Jennifer Teig von Hoffman
jtvh at bu.edu
Mon May 2 12:01:12 CDT 2005
I believe the Venue Management Manual provided by Argonne will give you
the info you need to set up a venue server. It's here:
http://www-unix.mcs.anl.gov/fl/research/accessgrid/documentation/VENUE_MANAGEMENT_MANUAL_HTML/VenueManagementManualHTML.htm
I'm unaware of whether anybody's documented how to provide a certificate
authority, which you'd also need running locally on a LAN. Anybody?
- Jennifer
Wan Sin NG wrote:
> Hi
> I would like to setup two PIGs using my internal office LAN. This is
> because our multicast connection will not be ready so soon.
> I will like to give it a try to setup my own venue server instead of
> connecting to ANL venue server via
> https//vv2.mcs.anl.gov:9000/Venues/default.
> I am reading up the "How to install & configure AG2.3 on a PIG for
> Windows" doc by Jennifer Teig von Hoffman but this assumes i can connect
> to ANL venue server.
> Can anyone tell me what do i need to do or point me to the right doc to
> setup/configure my own venue server?
> thanks very much
> wansin
