[AG-TECH] shared presentation fails to load presentation
Michael Braitmaier
braitmaier at hlrs.de
Mon May 2 01:56:50 CDT 2005
Hello gusain!
It sems to be different in your case, as you described the problem being caused by uploading the file which does not succeed in your case.
In any case having the log files make analysis of the problem easier.
Have you tried to upload plain text files and opening them by double clicking them in the data store?
If that does not succeed it might be a problem with general data store upload procedure.
In the end it would be helpful to have a look at your log file.
In contrast to Michael Blodget's problem you can still open a presentation if you load it from a webserver as you decsribed it, so I assume
that SharedPresentation in general is working correctly. I would advise checking the data store upload.
Michael
----- Original Message -----
To: Michael Braitmaier
Sent: Friday, April 29, 2005 7:07 PM
Subject: Re: [AG-TECH] shared presentation fails to load presentation
Hello Michael,
I'm not using win2k and yet i'm also facing the same problem.
But when I try to load file present on a webserver, there seems to
be no problem.But when I upload local file it doesn't get uploaded.
Need I send you the Log file.
Thanks
On 4/29/05, Michael Braitmaier <braitmaier at hlrs.de> wrote:
Looking at the Logfile, this seems to be a problem with your windows
machine, possible due to win2k.
The following line in the log
File "SharedPresentation.py", line 156, in LoadPresentation
> self.presentation = self.ppt.Presentations.Open(file)
> File
> "C:\Python23\Lib\site-packages\win32com\gen_py\91493440-5A91-11CF-8700-00AA0060263Bx0x2x7.py",
> line 3749, in Open
> ret = self._oleobj_.InvokeTypes(2005, LCID, 1, (13, 0), ((8, 1), (3,
> 49), (3, 49), (3, 49)),FileName, ReadOnly, Untitled, WithWindow)
> com_error: (-2147352567, 'Exception occurred.', (0, None, None, None,
> 0, -2147467259), None)
> 04/21/05 11:35:31 1876 SharedPresentation sharedpresentation.py:1502
> ERROR SharedPresentation.LocalLoadVenue: Can not load presentation
states that an OLE automation error (-2147352567) occured, which is caused
within the OLE component of Powerpoint.
I found a link to a forum discission where a reference is made to different
MDAC versions installed on your machines. Possibly that would be a point to
checkout. If thats the case maybe you should consider upgrading your MDAC
component.
Still there seem to be other possibilities. I add the link to the foruum
discussion for reference and hope it helps.
http://www.mail-archive.com/vbpro_databases@p2p.wrox.com/msg00383.html
Michael
From: "Michael Blodgett" <mblodget at cs.wisc.edu >
To: <ag-tech at mcs.anl.gov>
Sent: Thursday, April 28, 2005 10:02 PM
Subject: [AG-TECH] shared presentation fails to load presentation
>I have been working around this for awhile, fresh install of win2k, ag2.3.
>I can open a shared presentation, the control window pops up along with
>powerpoint app, it downloads the ppt file but then I get a popup window
>that it couldn't load the presentation. I found a similar report on the
>ag-tech mailing list last November but there were no replies. I included
>the shared presentation log message below. This problem look familar to
>anyone?
> Mike Blodgett
> UW-Madison,CS
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:90 DEBUG Initializing AG
> Toolkit version 2.3
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:132 INFO Logfile Name:
> SharedPresentation.log
> 04/21/05 11:35:21 1452 Toolkit config.py:196 DEBUG Using
> GLOBUS_HOSTNAME= ag-display.cs.wisc.edu as set in the environment
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:257
> DEBUG Opened repository C:\WINNT\Profiles\ag-op\Application
> Data\AccessGrid\Config\certRepo
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:395 DEBUG Got repo.
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:397 DEBUG looking in system
> ca dir: C:\Program Files\AGTk- 2.3\Config\CAcertificates
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:401 DEBUG Getting cert:
> 1c3f2ca8.0
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:406 WARNING Not importing
> cert C:\Program Files\AGTk- 2.3\Config\CAcertificates\1c3f2ca8.0
> 45cc9e80.0
> cert C:\Program Files\AGTk- 2.3\Config\CAcertificates\45cc9e80.0
> d1b603c3.0
> cert C:\Program Files\AGTk- 2.3\Config\CAcertificates\d1b603c3.0
> f18fa857.0
> cert C:\Program Files\AGTk- 2.3\Config\CAcertificates\f18fa857.0
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:410 DEBUG Init'ing globus.
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:734
> DEBUG Configuring standard environment
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:802
> DEBUG Using default identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.wisc.edu/CN=Michael Blodgett
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:873
> DEBUG Initializing environment with proxy cert for /O=Access
> Grid/OU= agdev-ca.mcs.anl.gov/OU=cs.wisc.edu/CN=Michael Blo
> dgett
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:907
> DEBUG Looking for identity (unused) None
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:892
> DEBUG Configuring for user proxy issued from /O=Access
> 04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:895
> DEBUG Proxy C:\WINNT\Profiles\ag-op\LOCALS~1\Temp\proxy will expire
> 04/21/05 18:26:51
> 04/21/05 11:35:21 1452 Toolkit toolkit.py:414 DEBUG Done with globus.
> 04/21/05 11:35:24 1452 EventClient eventclient.py:158 DEBUG Have
> callback handle _90725e02_p_callbackStruct
> 04/21/05 11:35:24 1452 SharedPresentation sharedpresentation.py:727
> DEBUG Registering for events.
> 04/21/05 11:35:24 1452 SharedPresentation sharedpresentation.py:735
> DEBUG Creating controller.
> 04/21/05 11:35:26 1876 SharedPresentation sharedpresentation.py:810
> DEBUG Got Event: local load venue None
> 04/21/05 11:35:26 1876 SharedPresentation sharedpresentation.py:1432
> DEBUG Method LocalLoadVenue called
> 04/21/05 11:35:27 1876 SharedPresentation sharedpresentation.py:1441
> DEBUG Got presentation:
> https://ivs.mcs.anl.gov:9006/00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt
> 04/21/05 11:35:30 1876 DataStore datastore.py:1643 DEBUG Host
> ivs.mcs.anl.gov:9006, path
> 04/21/05 11:35:30 1876 DataStore datastore.py:1645 DEBUG Connect to
> 04/21/05 11:35:30 1876 DataStore datastore.py:1648 DEBUG Downloading
> into C:\WINNT\Profiles\ag-op\LOCALS
> ~1\Temp\presentation.ppt
> 04/21/05 11:35:30 1876 DataStore datastore.py:1655 DEBUG before
> connect reqest path
> /00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt, headers {}
> 04/21/05 11:35:31 1876 DataStore datastore.py:1657 DEBUG after connect
> reqest
> 04/21/05 11:35:31 1876 DataStore datastore.py:1659 DEBUG request sent
> to <pyGlobus.io.GSIHTTPConnection instance at 0x04E9EB20>
> 04/21/05 11:35:31 1876 DataStore datastore.py:1663 DEBUG response is
> <httplib.HTTPResponse instance at 0x021EA468>
> 04/21/05 11:35:31 1876 DataStore datastore.py:1664 DEBUG Request got
> status 200
> 04/21/05 11:35:31 1876 DataStore datastore.py:1677 DEBUG Got hdr
> 3336704
> 04/21/05 11:35:31 1876 DataStore datastore.py:1678 DEBUG ['Server:
> BaseHTTP/0.3 Python/2.3.4\r\n', 'Date: Thu, 21 Apr 2005 16:33:01 GMT\r\n',
> 'Content-type: application/octet-stream\r\n',
> 'Content-Length: 3336704\r\n']
> 04/21/05 11:35:31 1876 SharedPresentation sharedpresentation.py:1484
> ERROR Can not load file
> https://ivs.mcs.anl.gov:9006/00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt 5
> Traceback (most recent call last):
> File "SharedPresentation.py", line 1481, in LocalLoadVenue
> self.viewer.LoadPresentation(tmpFile)
> File
> "C:\Python23\Lib\site-packages\win32com\gen_py\91493440- 5A91-11CF-8700-00AA0060263Bx0x2x7.py",
> line 3749, in Open
> ERROR SharedPresentation.LocalLoadVenue : Can not load presentation
> 04/21/05 11:35:43 1452 SharedPresentation sharedpresentation.py:762
> DEBUG Shutting down...
> 04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:810
> DEBUG Got Event: local quit None
> 04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:1216
> DEBUG Method Quit called
> 04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:1234
> ERROR Exception destroying controller. This happens when using the x
> button in the top right corner. Not critical.
> File "SharedPresentation.py", line 1232, in Quit
> self.controller.frame.Destroy()
> File "C:\Python23\Lib\site-packages\wx\core.py", line 9344, in
> __getattr__
> raise PyDeadObjectError(self.attrStr % self._name)
> PyDeadObjectError: The C++ part of the SharedPresentationFrame object has
> been deleted, attribute access no longer allowed.
> 04/21/05 11:35:44 1452 EventClient eventclient.py:303 DEBUG Cancel
> pending callbacks
> 04/21/05 11:35:44 1948 EventClient eventclient.py:177 DEBUG Read
> Callback called arg=None handle=_08ef5c02_p_globus_io_handle_t result=(-1,
> 2, 'an I/O operation was cancelled') n=0
> 04/21/05 11:35:44 1948 EventClient eventclient.py:180 DEBUG
> readCallback gets failure in result: -1 2
> 04/21/05 11:35:44 1452 EventClient eventclient.py:309 DEBUG Free
> callback _90725e02_p_callbackStruct
> 04/21/05 11:35:44 1452 EventClient eventclient.py:315 DEBUG
> EventClient.Stop: closing socket
> 04/21/05 11:35:44 1452 EventClient eventclient.py:323 DEBUG
> EventClient.Stop: closing queue
Rajpal Singh
Patience and Perseverance can overcome mountains.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050502/d7c51899/attachment.htm>
