[AG-TECH] PiGs on WLAN
    Andrew Daviel
    advax at triumf.ca
    Thu Mar 17 00:35:03 CST 2005
I recently tried to use a laptop PiG on a WLAN. The venue client took an
unreasonably long time (on a 1.2GHz thinkpad) to start, causing everyone
to decamp to another building with a permanent AG setup.
Brian Corrie noted that he had been caught if a real IP number from a
previous location or wired LAN is saved in the node
configuration rather than localhost. Then if the venue client can't
contact the node manager it may take a very long time to timeout.
Something to look out for - and it would be nice if these things did not
block the main venue client process.
Andrew Daviel, TRIUMF, Canada
Tel. +1 (604) 222-7376  (Pacific Time)
security at triumf.ca
