[AG-TECH]X509 CN, VenueServer configfile and profile, PII
Thomas D. Uram
turam at mcs.anl.gov
Tue Mar 15 09:45:33 CST 2005
West Suhanic wrote:
>>>1)What is the relationship between the CN embedded in the X509
> certificate
>>>and the user ID running the VenueClient. I have had cases where if the
> two
>>>differ I get an authorization failure when trying to get into the
> VenueServer.
>>Each user has a certificate repository, and within that repo a default
> certificate that is
>>used for running the venue client and other AG software. I'm not sure
> what you mean when
>>you say 'if the two differ'. Can you clarify?
> Hi Thomas:
> To clarify, suppose the CN in the certificate is set to West Suhanic but the
> user ID that I am
> logged in as is wsuhanic. I have received authorization failures when trying
> to connect to a VenueServer
> via a VenueClient with the CN=West Suhanic but the login ID set to wsuhanic.
> The only remedy was to
> set the CN to wsuhanic .
The only dependency I can imagine in this case is that you changed authorization to allow
actions for 'CN=wsuhanic', but not for 'CN=West Suhanic'. You should check that in the
venue server authorization.
>>>2)How does one create a configfile for the VenueServer? Could I please
> have
>>>an example configfile.
>>>(I would like to create it without using an interface. Editing it with
> vi is
>>>preferable.)
>>The VenueServer will create a config file with defaults when it runs.
> Most of the options
>>are configurable using the VenueManagement application. You can certainly
> edit with vi if
>>you like, but you run the risk of invalidating the config file.
> Can you please tell me where I can find the VenueServer config file.
VenueServer.py creates VenueServer.cfg and VenueServer.dat in the current directory.
> best regards,
> west
