[AG-TECH]X509 CN, VenueServer configfile and profile
West Suhanic
giraffe911 at rogers.com
Sun Mar 13 22:46:02 CST 2005
Hi Thomas:
I have a few questions:
1)What is the relationship between the CN embedded in the X509 certificate
and the user ID running the VenueClient. I have had cases where if the two
differ
I get an authorization failure when trying to get into the VenueServer.
2)How does one create a configfile for the VenueServer? Could I please have
an example configfile.
(I would like to create it without using an interface. Editing it with vi is
preferable.)
3)How does one create a service profile? Could I please have an example
service profile.
preferable.)
regards,
West
----- Original Message -----
To: "West Suhanic" <wsuhanic at alumni.uwaterloo.ca>
Cc: <ag-tech at mcs.anl.gov>
Sent: Thursday, February 17, 2005 4:12 PM
Subject: Re: [AG-TECH] VIC won't start
> Hi West:
> The venueserver allocates multicast addresses dynamically by default.
When someone enters
> the venue and will be sending video, a multicast address is allocated and
used. If no one
> in the venue is sending video, there will be no mcast address for it, so
when you enter
> with a consumer-only setup, vic will not start.
> If you add a producer to your setup, and enter the venue, things should
work fine.
> Alternately, you can configure the venue to use static mcast addresses for
audio and
> video, and then your consumer vic will start (showing no video streams, of
course).
> Tom
> West Suhanic wrote:
> > Hi All:
> > I am running a venue server on a linux machine. I am using my own
> > certificates-(my own root CA,
> > which is used to generate a service certificate for the venue server and
> > user certificate for the
> > venue client).
> > I can successfully log on to the venue server via a venue client.
However
> > only RAT will
> > start. VIC will not start if I enable VideoConsumerService.
> > I have gone through the logs extensively there is nothing obvious to my
> > eyes.
> > Any suggestions would, as usual, be greatly appreciated.
> > regards,
> > west
