[AG-TECH] Problems running Venue Server on Suse 9.2
Jan Göbel
j.goebel at fh-mannheim.de
Tue Mar 8 04:32:25 CST 2005
Hello Everybody,
I´ve just installed the Accessgrid Toolkit 2.3 on a Suse 9.2 Linux
system. Starting the venue client, the installation of the certificate
functions perfectly, but running the Venue Server the following error
messages are beeing displayed:
/usr/lib/python2.3/pyGlobus/security.py:11: RuntimeWarning: Python C API
version
mismatch for module gssc: This Python has API version 1012, module gssc
has
ver
sion 1011.
from pyGlobus import gssc
/usr/lib/python2.3/pyGlobus/security.py:12: RuntimeWarning: Python C API
version
mismatch for module utilc: This Python has API version 1012, module
utilc
has v
ersion 1011.
from pyGlobus import utilc
/usr/lib/python2.3/pyGlobus/security.py:13: RuntimeWarning: Python C API
version
mismatch for module proxyc: This Python has API version 1012, module
proxyc
has
version 1011.
from pyGlobus import proxyc
/usr/lib/python2.3/pyGlobus/io.py:14: RuntimeWarning: Python C API
version
mismatch for module ioc: This Python has API version 1012, module ioc
has
version 1011.
import ioc
Traceback (most recent call last):
File "/usr/bin/VenueServer.py", line 133, in ?
main()
File "/usr/bin/VenueServer.py", line 92, in main
server = SecureServer((hostname, port))
File "/usr/lib/python2.3/AccessGrid/hosting/SOAPpy/Server.py", line
254,
in __init__
s = ThreadingGSISOAPServer(addr, config = self.config)
File
"/mnt/scratch/AG2.3/AccessGrid-2.3/dist-20050209_115112/lib/python2.3/si
te-packages/SOAPpy/GSIServer.py",
line 137, in __init__
File "/usr/lib/python2.3/pyGlobus/io.py", line 1367, in __init__
channel_mode, delegation_mode, tcpAttr)
File "/usr/lib/python2.3/pyGlobus/io.py", line 797, in __init__
self.server_bind()
File "/usr/lib/python2.3/pyGlobus/io.py", line 813, in server_bind
self.server_address[1])
File "/usr/lib/python2.3/pyGlobus/io.py", line 1035, in
create_listener
raise ex
pyGlobus.io.GSITCPSocketException: a system call failed (Address already
in
use)
Who can help me solving this problems ?
Thank you for your support,
Jan
Dipl. Ing. (FH) Jan Göbel
Institut für CAE- Anwendungen
Fachbereich Maschinenbau
Fachhochschule Mannheim
Windeckstraße 110
68163 Mannheim
Tel.: +49(0)621 292 6549
Fax: +49(0)621 292 6481
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050308/162f0a2a/attachment.htm>
