[AG-TECH] vic works on command line but fails to be started via AG
Thomas D. Uram
turam at mcs.anl.gov
Wed Jun 22 07:48:02 CDT 2005
You might also check the logfile for failures that occurred in trying to start vic.
Logfiles reside in C:\Documents and Settings\%USERNAME%\Application Data\AccessGrid\Logs,
named according to the service (e.g., VideoService.log).
Tom
On 06/22/05 01:29, Natalia Costas Lago wrote:
> Have a look at the venue log, to check which kind of call the venue
> client does to start vic and check errors.
> ----- Original Message ----- From: "west suhanic" <west.suhanic at gmail.com>
> To: <ag-tech at mcs.anl.gov>
> Sent: Wednesday, June 22, 2005 5:17 AM
> Subject: Re: [AG-TECH] vic works on command line but fails to be started
> via AG
>> Hi All:
>> vic fails to come up on a Windows XP laptop. However when I
>> start vic on the command line it shows the video streams. Other
>> than a re-install, any suggestions?
>> regards,
>> west
>> On 6/21/05, west suhanic <west.suhanic at gmail.com> wrote:
>>> Hi Thomas:
>>> I checked the emerge log. I did not see any complaint about or even
>>> mention of /etc/AccessGrid. I did not see mention of /etc . Also there
>>> was no
>>> ~/.AccessGrid created. I am open to any and all suggestions.
>>> regards,
>>> west
>>> On 6/21/05, Thomas D. Uram <turam at mcs.anl.gov> wrote:
>>> > The complaint is about /etc/AccessGrid/SharedApplications .
>>> > I expect to see some failure in the emerge output regarding this
>>> and > other directories.
>>> > West: Do you see any failures regarding directories in >
>>> /etc/AccessGrid? Do you see a
>>> > complaint about configuration files (which reside in /etc)?
>>> > Tom
>>> > On 06/20/05 17:22, Douglas Kosovic wrote:
>>> > > Hi West,
>>> > >> File
>>> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>>> > >> line 100, in _Initialize
>>> > >> self.GetSharedAppDir()
>>> > >> File
>>> > >> line 208, in GetSharedAppDir
>>> > >> raise Exception, "AGTkConfig: app dir does not exist."
>>> > >> Exception: AGTkConfig: app dir does not exist.
>>> > >> Any suggestions?
>>> > > I think it's complaining about either one of the following dirs:
>>> > > ~/.AccessGrid/SharedApplications/
>>> > > $AGTK_USER/SharedApplications/
>>> > > The latter only if the AGTK_USER env variable is set.
>>> > > Check the ownership and permissions of ~/.AccessGrid/ or just issue
>>> > > something like:
>>> > > mv ~/.AccessGrid ~/AccessGrid.bak
>>> > > Cheers,
>>> > > Doug
